[mapserver-users] request help with projection
David Armstrong david.armstrong at ntlworld.com
Wed Jan 9 10:01:10 EST 2002
Could someone on the list confirm if i have this correct :-
I need to use projection using 2 layers , one being my map and the other
being my gps , the gps unit is fixed in WGS84 and the datum etc cannot be
changed , and i am trying to overlay my gps layer on the map.
the map i have is :-
NAD_1927_Stateplane_Texas_South_Central_Fips_4204
Looking this up i belive the map layer  projection should be
PROJECTION
proj=lcc
datum=NAD27
END
and the gps layer  should be
WGS84 Decimal Degrees (EPSG 4326)
PROJECTION
   proj=latlong
   ellps=wgs84
END
Should i just be able to set the output map to the same as the map layer for
correct use !
any help appriciated , this problem is cracking me up !
Regards
Dave
