[mapserver-users] request help with projection
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 9 14:16:23 EST 2002
David Armstrong wrote:
> Could someone on the list confirm if i have this correct :-
> I need to use projection using 2 layers , one being my map and the other
> being my gps , the gps unit is fixed in WGS84 and the datum etc cannot be
> changed , and i am trying to overlay my gps layer on the map.
> the map i have is :-
> NAD_1927_Stateplane_Texas_South_Central_Fips_4204
> Looking this up i belive the map layer projection should be
> PROJECTION
> proj=lcc
> datum=NAD27
> END
> and the gps layer should be
> WGS84 Decimal Degrees (EPSG 4326)
> PROJECTION
> proj=latlong
> ellps=wgs84
> END
> Should i just be able to set the output map to the same as the map layer for
> correct use !
David,
I think you need to use:
> PROJECTION
> proj=latlong
> datum=WGS84
> END
Saying the ellipse is WGS84 isn't quite the same as saying the datum is, and so
PROJ won't try to do the datum conversion. At least I imagine that is your
problem.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
