[mapserver-users] php_mapscript.so linkage problem?
John Carlson carlson14 at llnl.gov
Wed Jan 9 15:05:58 EST 2002
I suspect there's a difference in your environment between the web server
context
and your command line context.  But I don't guarantee that.
John
At 02:38 PM 1/9/2002 -0500, Doyon, Jean-Francois wrote:
>Hello all,
>I just tried to look at this problem again, and am still baffled.
>"ldd php_mapscript.so" suggests everything is fine! And the compile went
>without a hitch (Excpet for the odd usual warnings).
>I'm still not sure where the "main" symbol is supposed to come from, or why
>"httpd" is the one throwing the exception ... shouldn't it be libphp.so
>complaining?
>Any help would be greatly appreciated!
>Thanks!
>J.F.
>-----Original Message-----
>From: Doyon, Jean-Francois [mailto:Jean-Francois.Doyon at CCRS.NRCan.gc.ca]
>Sent: Friday, December 28, 2001 11:21 AM
>To: 'mapserver-users at lists.gis.umn.edu'
>Subject: [mapserver-users] PHP Problem
>Hello,
>I jus tried to compile/setup PHP mapscript for the first time in a while and
>am having problems.
>The machine is a SunOS 5.8 with Apache 1.3.20 and PHP 4.0.6 compiled with:
>'./configure' '--with-apxs=/usr/local/apache/bin/apxs' '--without-mysql'
>'--with-system-regex' '--with-yaz'
>phpinfo() works fine.
>Then I compile Mapserver from the official 3.5 tarball using:
>./configure  --with-proj --with-wmsclient --with-gdal --with-ogr
>--with-php=/usr/src/php-4.0.6/ --with-apxs=/usr/local/apache/bin/apxs
>No problems there, apart from the odd warning.
>But when I try to use dl() just before the phpinfo() I get:
>Warning: Unable to load dynamic library
>'/usr/local/lib/php/extensions/no-debug-non-zts-20001222/php_mapscript.so' -
>ld.so.1: /usr/local/apache/bin/httpd: fatal: relocation error: file
>/usr/local/lib/php/extensions/no-debug-non-zts-20001222/php_mapscript.so:
>symbol main: referenced symbol not found in /home/httpd/html/info.php on
>line 3
>Anybody seen this before? The ldd output looks fine, so all the libs are OK
>... I'm not sure what that symbol is ... "main" .. sounds to me like it
>should be internal, so how could it not find it? :)
>Help!
>Thanks,
>Jean-François Doyon
>Internet Service Development and Systems Support
>GeoAccess Division
>Canadian Center for Remote Sensing
>Natural Resources Canada
>http://atlas.gc.ca
>Phone: (613) 992-4902
>Fax: (613) 947-2410
