[mapserver-users] php_mapscript.so linkage problem?
John Carlson
carlson14 at llnl.gov
Thu Jan 10 19:25:46 EST 2002
Specificallly, I mean the LD_LIBRARY_PATH environmental variable. I don't
really
know how PHP works at all. I've never used it. The environment you start the
web server in may be different than your user environment.
John
At 03:14 PM 1/9/2002 -0500, Doyon, Jean-Francois wrote:
>What do you mean by context exactly? The common problem here would be the
>linker, but they abviously both share .. oh wait maybe not, could it because
>I think that system may have 2 linkers on it ... the Solaris LD and the GNU
>LD ... hmmm I'll look into that ...
>Thanks!
>J.F.
>-----Original Message-----
>From: John Carlson [mailto:carlson14 at llnl.gov]
>Sent: Wednesday, January 09, 2002 3:06 PM
>To: Doyon, Jean-Francois; 'mapserver-users at lists.gis.umn.edu'
>Subject: Re: [mapserver-users] php_mapscript.so linkage problem?
>I suspect there's a difference in your environment between the web server
>context
>and your command line context. But I don't guarantee that.
>John
>At 02:38 PM 1/9/2002 -0500, Doyon, Jean-Francois wrote:
> >Hello all,
> >I just tried to look at this problem again, and am still baffled.
> >"ldd php_mapscript.so" suggests everything is fine! And the compile went
> >without a hitch (Excpet for the odd usual warnings).
> >I'm still not sure where the "main" symbol is supposed to come from, or why
> >"httpd" is the one throwing the exception ... shouldn't it be libphp.so
> >complaining?
> >Any help would be greatly appreciated!
> >Thanks!
> >J.F.
> >From: Doyon, Jean-Francois [mailto:Jean-Francois.Doyon at CCRS.NRCan.gc.ca]
> >Sent: Friday, December 28, 2001 11:21 AM
> >To: 'mapserver-users at lists.gis.umn.edu'
> >Subject: [mapserver-users] PHP Problem
> >Hello,
> >I jus tried to compile/setup PHP mapscript for the first time in a while
>and
> >am having problems.
> >The machine is a SunOS 5.8 with Apache 1.3.20 and PHP 4.0.6 compiled with:
> >'./configure' '--with-apxs=/usr/local/apache/bin/apxs' '--without-mysql'
> >'--with-system-regex' '--with-yaz'
> >phpinfo() works fine.
> >Then I compile Mapserver from the official 3.5 tarball using:
> >./configure --with-proj --with-wmsclient --with-gdal --with-ogr
> >--with-php=/usr/src/php-4.0.6/ --with-apxs=/usr/local/apache/bin/apxs
> >No problems there, apart from the odd warning.
> >But when I try to use dl() just before the phpinfo() I get:
> >Warning: Unable to load dynamic library
> >'/usr/local/lib/php/extensions/no-debug-non-zts-20001222/php_mapscript.so'
> >ld.so.1: /usr/local/apache/bin/httpd: fatal: relocation error: file
> >/usr/local/lib/php/extensions/no-debug-non-zts-20001222/php_mapscript.so:
> >symbol main: referenced symbol not found in /home/httpd/html/info.php on
> >line 3
> >Anybody seen this before? The ldd output looks fine, so all the libs are OK
> >... I'm not sure what that symbol is ... "main" .. sounds to me like it
> >should be internal, so how could it not find it? :)
> >Help!
> >Thanks,
> >Jean-François Doyon
> >Internet Service Development and Systems Support
> >GeoAccess Division
> >Canadian Center for Remote Sensing
> >Natural Resources Canada
> >http://atlas.gc.ca
> >Phone: (613) 992-4902
> >Fax: (613) 947-2410
