[mapserver-users] Rotating a map
Tyler Mitchell TMitchell at lignum.com
Fri Jan 11 11:32:05 EST 2002
Frank Warmerdam wrote:
>As it happens GDAL will read these in and use these rotational
coefficients
>when going through the resampling process, so the image gets rotated back
>to north-up.  You can accomplish the same thing by putting rotational
>coefficients in a world file.  The above file would have a world file that
>looks like this:
Will this only apply to an image layer as it is loaded?
What about changing the whole map before it is display in the browser - any
ideas?
                    Frank Warmerdam
                    <warmerdam at pobox.com>               To:     Tyler Mitchell <TMitchell at lignum.com>
                    Sent by:                            cc:     UMN MapServer <mapserver-users at lists.gis.umn.edu>
                    owner-mapserver-users at lists.g       Fax to:
                    is.umn.edu                          Subject:     Re: [mapserver-users] Rotating a map
                    01/10/2002 05:49 PM
                    Please respond to warmerdam
Tyler Mitchell wrote:
> Hi guys,  what would you do to rotate the orientation of your map?  Is
> using Proj realistic or not?
> I saw some emails back in July about this question - has anyone gone
> anywhere with this idea?
Tyler,
I have successfully used the resampling code in MapServer to do some
rotation of an ortho image.  In my particular test the georeferencing
information in a GeoTIFF file included rotational coefficients as shown
here:
warmerda at gdal[483]% listgeo small.tif
Geotiff_Information:
    Version: 1
    Key_Revision: 1.0
    Tagged_Information:
       ModelTransformationTag (4,4):
          0.999978707      -0.0065257527    0                467086.89
          -0.0065257527    -0.999978707     0                5365917.48
          0                0                0                0
          0                0                0                1
       End_Of_Tags.
    Keyed_Information:
       End_Of_Keys.
    End_Of_Geotiff.
As it happens GDAL will read these in and use these rotational coefficients
looks like this:
warmerda at gdal[487]% more small.tfw
             0.9999787070
            -0.0065257531
            -0.0065257527
            -0.9999787072
        467087.3871740954
       5365916.9739565337
Please feel free to contact me if you have problems settings this up and
doing it.  It is a rather esoteric use of the mapserver resampling logic.
PS. I have placed this text in the Wiki as:
   http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?RotatingImages
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
