[mapserver-users] Re: Mapscript
Jim Burnett
jimburnett at ntelos.net
Sun Jan 13 14:54:21 EST 2002
well, I am using MySQL server, not oracle, should this work with any sql
engine?
-jim
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Saturday, January 12, 2002 8:11 AM
Subject: Re: [mapserver-users] Re: Mapscript
> Hello all,
> Well, I'll try to shed some light into this discussion, regarding the SDO
> part. About the shape_id, there are a few alternatives for Oracle
> Spatial, but it will depend on how I will provide support for the last
> functions that are missing implementation in our MapServer-SDO interface.
> In Oracle Spatial I can provide a shape_id by using a "rownum" request in
> the SELECT statement. Therefore, it will give me numbered ids that could
be
> used for uniquely identifying each record. On the other hand, it's also
very
> common for the user to define a column which is the unique key for the
> table, namely a GID. So it would be a matter of including in the mapfile
> "DATA" definition the name of the shape_id column, like this:
> DATA "shape_column FROM mytable" (as it's today)
> DATA "shape_column,shape_id FROM mytable" (could be implemented)
> But as I mentioned recently in another email, Oracle Spatial has a good
set
> of functions for performing spatial queries in the database. So, for the
> time being, I'm using those functions instead of going through MapServer's
> interface. I have 3 very good reasons why one should choose this approach.
> Please check the following URL, which is an loong email on the subject.
> http://mapserver.gis.umn.edu/wilma/mapserver-users/0201/msg00129.html
> Rod.
> From: "Daniel Morissette" <morissette at dmsolutions.ca>
> To: "Jim Burnett" <jimburnett at ntelos.net>
> Cc: "mapserver-users" <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, January 11, 2002 8:14 PM
> Jim Burnett wrote:
> > I've been looking into using getShap(), but doesnt it require the index
of
> > the shape? Not all databases will have this Index. I think you can get
the
> > shap via a class, but the shapeObj doesnt seem to work correctly. Do you
> > have any sample code for drawing a shape, getting the shape by class,
not
> by
> > the shape index?
> I think I see what you mean: reocrds obtained from a RDBMS won't carry a
> unique shape_id the same way as shapefiles and other file-based formats
> will. So you don't have any shape_id to pass to getShape() after a
> query. I don't know about SDE and PostGIS, but I have used SDO before
> (outside of the MapServer world) and I believe that there is nothing in
> OracleSpatial that can easily be mapped to a shape_id.
> I guess the best ones to answer this question are the developers of the
> SDO, SDE, and/or PostGIS connections: Do the database-based connections
> in MapServer have any equivalent of a shape_id? If not then what should
> one do to retrieve the shapes returned by a queryByPoint() in MapScript
> for instance?
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
