[mapserver-users] Expression statement (FWD)
teb
teb at mallit.fr.umn.edu
Mon Jan 14 16:36:32 EST 2002
------------- Begin Forwarded Message -------------
X-Sender: geo402 at mailms.abdn.ac.uk
Date: Mon, 14 Jan 2002 16:58:06 +0000
To: mapserver-info at lists.gis.umn.edu
Subject: Expression statement
Mime-Version: 1.0
X-Scanner: exiscan *16QAUW-0003fz-00*CIeUL4fe4fk*
I am trying to get mapserver to display classes from one shapefile -
without success - I just get a blank image. I can get it to display the
shapefile without the class divisions.
The shapefile is called Gr_nhs.shp
It is divided up into 23 classes. Each class takes its value from the
Grid_code attribute field. -9999 is unknown, the remaining values are from
1-22
In my map file, the layer definition is as follows:
LAYER
NAME Gr_nhs
TYPE POLYGON
STATUS DEFAULT
DATA Gr_nhs
CLASSITEM "Grid_code"
CLASS
Name "Unknown"
EXPRESSION ([Grid_code] eq -9999)
COLOR 210 275 25
END
END
END # Map file
I have tried various combinations for the expression - can anyone help?
Thanks,
Stephen
------------- End Forwarded Message -------------
