[mapserver-users] Dynamic generated layer?
Frank Koormann
frank.koormann at intevation.de
Fri Jan 18 11:13:15 EST 2002
Twan,
* Twan Kogels (twan at twansoft.com) [020118 15:38]:
> Hello all,
> But now i'm planning to implement a search function. So i wrote a php
> script (mapscript) which sets the "data" en "filter" properties in the
> code, pseudo code:
> $layer->setFilter("name='$name'");
> $layer->set("data", "the_geom from towns");
> This will display all towns with names which matches "name='$name'". But
> when i do this the orginal towns will disappear, i don't want that to
> happen.
> Is it possible to have the orginal towns layer and on top of that a dynamic
> generated layer of the search result?
This can easily be acheived by using a seperate layer definition for the
search, with "STATUS OFF" in the map file. Activating this layer
explicitely and setting filter etc. will result in the functionality you
need.
Regards,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
