[mapserver-users] Dynamic generated layer?
Steve Lime
steve.lime at dnr.state.mn.us
Fri Jan 18 14:30:08 EST 2002
It's just as efficient as from a map file, they populate the exact same
C structure.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Twan Kogels <twan at twansoft.com> 01/18/02 11:29AM >>>
Frank,
> > Is it possible to have the orginal towns layer and on top of that a
> dynamic
> > generated layer of the search result?
>This can easily be acheived by using a seperate layer definition for
the
>search, with "STATUS OFF" in the map file. Activating this layer
>explicitely and setting filter etc. will result in the functionality
you
>need.
That's a really easy solution! I will implement your solution.
Just for curiousity: i saw that mapscript allows me to create a layer
with
the ms_newLayerObj() function. When using this function to create a
layer,
will there be a performance hit? Or is creating a layer with mapscript
just
as efficient as a layer in a .map file.
Thanks!
Twan
http://www.twansoft.com
