[mapserver-users] projection problem
David Armstrong
david.armstrong at ntlworld.com
Sun Jan 20 05:08:01 EST 2002
Could someone on the list please check the attached map file
for whatever reason i am unable to get the gps layer projection to work , am
i missing some crucial entrys
the map layer appears to work ok but not able to overlay the GPS wgs84
layer
This is driving me nuts!
Regards
Dave
<>--- map file -----<>
map
extent 2768239.002073439 504002.5248415045 3462077.742742627
895960.5502721686
# extent 2929104.53692815 -534387.296051676
3296713.81437212 -864213.337652181
imagecolor 255 255 255
name "FINAL"
shapepath "data"
size 600 600
status on
# SYMBOLSET "symbols\all.sym"
SYMBOLSET "symbols\symbols.sym"
#set map output to projection required
#note that extents need to be set to the same as the output map projection
# not needed here as the map is the same as the output map projection
required
# 4204: texas south central: nad27
PROJECTION
proj=lcc
lat_1=28.383333333
lat_2=30.283333333
lat_0=27.833333333
lon_0=-99.000000000
x_0=609601.219
y_0=0.000
ellps=clrk66
datum=NAD27
to_meter=0.3048006096
END #end projection
# 1 scalebar #none
scalebar
backgroundcolor 255 255 0
color 255 255 255
intervals 4
outlinecolor 0 0 0
size 200 7
status on
style 0
transparent true
units feet
# 1 label #none
label
backgroundcolor 0 0 0
color 255 255 0
size tiny
end
end
# 2 layer Grant
LAYER
# CLASSITEM "ContractID"
DATA Grant
GROUP Grant
# LABELCACHE on
# LABELITEM "ContractID"
NAME Grant
# POSTLABELCACHE true
STATUS ON
TYPE POINT
#set projection of gps , note that this needs to be wgs84 in decimal degrees
for gps
#WGS84 Decimal Degrees (EPSG 4326)
PROJECTION
proj=latlong
datum=WGS84
END
# 1 class Grant_1
CLASS
BACKGROUNDCOLOR 128 128 128
SYMBOL "circle"
SIZE 16
COLOR 110 110 128
NAME 'Grant_1'
OUTLINECOLOR 0 0 0
END
END
# 3 layer roadharr_orig
layer
classitem "FNODE_"
data "roadharr_orig"
group "roadharr_orig"
labelcache on
labelitem "FNODE_"
name "roadharr_orig"
postlabelcache true
status on
type line
#set projection of map layer,
#not sure if we need this as the map is the same as the output map
# we should get away with setting the output map projection and only the gps
layer
#NAD_1927_Stateplane_Texas_South_Central_Fips_4204
PROJECTION
proj=lcc
lat_1=28.383333333
lat_2=30.283333333
lat_0=27.833333333
lon_0=-99.000000000
x_0=609601.219
y_0=0.000
ellps=clrk66
datum=NAD27
END
# 1 class roadharr_orig_1
class
backgroundcolor 128 128 128
color 128 128 128
name "roadharr_orig_1"
outlinecolor 0 0 0
end
end
# 4 web FINAL.html
web
footer "FINAL_footer.html"
header "FINAL_header.html"
imagepath "c:\phpdev\www\tmp\"
imageurl "/tmp/"
template "FINAL.html"
end
# 5 querymap hilite
querymap
color 255 0 0
size 200 200
status on
style hilite
end
# 6 reference graphics/reference.gif
reference
color -1 -1 -1
895960.5502721686
#extent 2929104.53693 534387.296052 3296713.81437 952327.2342
image "graphics/reference.gif"
outlinecolor 255 0 0
size 120 120
status on
end
# 7 legend #none
legend
keysize 18 12
status on
# 1 label #none
label
color 0 0 89
size medium
type bitmap
end
end
end
<> end map file <>
