[mapserver-users] OGR Support
Luca Pescatore
info at pescatoreluca.com
Sun Jan 20 17:56:38 EST 2002
i'm trying to compie MapServer with OGR Support, it seem to be configured
correctly but when i use php_info don't get OGR Support
Mapserver is 3.5
configure options are :
./configure --with-ogr=/usr/src/gdal-1.1.5/ogr
--with-php=/usr/src/php-4.0.6/ --with-apxs=/usr/local/apache/bin/apxs
Configure output (partial output)
>checking whether we should include OGR support...
> using OGR from /usr/src/gdal-1.1.5/ogr.
>checking if GDAL support requested... no
php_info output :
MapScript Version (Nov 27, 2001)
MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
What's wrong ?
I need to compile OGR Support because i need to read some map file like in
http://195.219.91.250/mapinfo.zip and arcview.zip (are in SHP and MapInfo
format)
Someone have a little snippet of code that display a rectangle or a point
on a map ?
Best Regards,
Luca
