[mapserver-users] Error with stable build of mapserv 3.5
Trem Stamp trem at socialchange.net.au
Sun Jan 20 23:35:07 EST 2002
We have just rebuilt the mapserv executable using the 18 December stable build and are using the same mapfiles that worked with a build prior to this. (working on a Solaris box)
I seem to get errors with the new build however.
getSymbol(): Symbol definition error. (Points):(4)
The Urls are:
The map file is the same in both cases.
Working:
http://maps-dev.socialchange.net.au/cgi-bin/mapserv?map=mapfiles/urban1.map&WMTVER=1.0.0&SRS=EPSG%3A4202&REQUEST=map&FORMAT=GIF&TRANSPARENT=true&EXCEPTIONS=INIMAGE&BBOX=138.863%2C-38.830714285714286%2C154.577%2C-29.443285714285715&WIDTH=400&HEIGHT=400&LAYERS=populated&STYLES=
Not working:
http://maps-dev.socialchange.net.au/cgi-bin/mapserv-3.5?map=mapfiles/urban1.map&WMTVER=1.0.0&SRS=EPSG%3A4202&REQUEST=map&FORMAT=GIF&TRANSPARENT=true&EXCEPTIONS=INIMAGE&BBOX=138.863%2C-38.830714285714286%2C154.577%2C-29.443285714285715&WIDTH=400&HEIGHT=400&LAYERS=populated&STYLES=
The mapfile remains the same:
# Start of layer definitions
bash-2.04$ cat urban1.map
# Start of map file - created Tue Aug 29 15:24:42 2000
NAME demo
EXTENT -180 -90 180 90
SHAPEPATH "/www/hosted/maps-dev/htdocs/mapserv/data/urban"
SYMBOLSET "/www/hosted/maps-dev/htdocs/mapserv/symbology/symbol.sym"
FONTSET "/www/hosted/maps-dev/htdocs/mapserv/fonts/fonts.list"
PROJECTION
"init=epsg:4326"
END
# Contains the map metadata (capabilities)
WEB
   METADATA
    "wms_abstract" "This map file serves cadastral data which may be used for backdrops to base maps"
    "wms_keywordlist" "Shapefile, MapInfo data, towns, places, gazetteer"
    "wms_contactperson" "Trem Stamp"
    "wms_contactorganization" "Social Change Online"
    "wms_contactposition" "Application Developer"
    "wms_addresstype" "Mapping research and development"
    "wms_address" "248, Johnston Street"
    "wms_city" "Annandale"
    "wms_stateorprovince" "New South Wales"
    "wms_postcode" "2038"
    "wms_country" "Australia"
    "wms_contactvoicetelephone" "none"
    "wms_contactfacsimiletelephone" "(02) 9692 5192"
    "wms_contactelectronicmailaddress" "trem at socialchange.net.au"
    "wms_accesscontraints" "none"
    "wms_title" "WMS Server: Base maps"
    "wms_fees" "none"
    "wms_onlineresource" "http://maps-dev.socialchange.net.au/cgi-bin/mapserv?map=mapfiles/urban.map"
    "wms_srs" "EPSG:4326 EPSG:4202"
    END
END
LAYER
  NAME populated
  TYPE annotation
  STATUS ON
   CONNECTIONTYPE OGR
   CONNECTION "/www/hosted/maps-dev/htdocs/mapserv/data/urban/populated.shp"
  METADATA
    "wms_title" "towns in NSW"
    "wms_extent" "138 -39.0 154 -28"
  END
  PROJECTION
  "init=epsg:4326"
  END
  CLASSITEM Pppttype
  CLASS
    NAME "townname"
    EXPRESSION "2"
   TEXT ([Ppptname])
    SYMBOL town
    SIZE 11
    OUTLINECOLOR  6 70 6
    COLOR 255 0 102
    LABEL
     COLOR 0 0 0
     FORCE false
     POSITION ul
     MINSIZE 5
     MAXSIZE 36
     MINDISTANCE 5
     SIZE 10
     TYPE truetype
     FONT arial_bold
    END
  END
END
END
END
Does anyone know why the latest build will no longer work with the latest build?
I noticed that the new build has SUPPORTS=WMS_SERVER rather than the old SUPPORTS=WMS - will this have any effect?
Cheers,
Trem
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020121/c1ddacb0/attachment.html
