[mapserver-users] shptree bug and RFI
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 22 11:52:05 EST 2002
Folks,
DM Solutions Group was encountering a bug with how the byte order of .qix
files was detected but only in a small fraction of files. In BugZilla I
wrote:
> I have applied a fix to maptree.c. The logic to establish if a .qix file
> was MSB or LSB was to inspect the first byte and check if it was zero. The
> assumption was that if it was zero it was the high order byte of the shape
> count (and hence MSB). but of course even on LSB system the low order byte
> is 0 in about 1 in 256 times.
> I modified the maptree open code to look at the first two bytes of the
> "maximum depth" value in the header. If this is zero it is assumed to be
> MSB otherwise LSB. This is based on the assumption that maximum depth is
> always between 1 and 65535. Given that typical values are in the range of
> 4-15 I think it is OK.
Also, because I had some trouble figuring out how shptree, and the related
utilities work, I wrote up a few notes on them, and posted it on the wiki.
I would appreciate it if Steve Lime, or Carl Anderson would add a little
information about the old vs. new index format and any hints for usage.
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?ShpTree
I have also created a general utilities node in the Wiki with links to this
and some other utilities. I encourage others to add more detailed notes on
the utilities in the Wiki as the online documentation for them is generally
sparse at this time.
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?UtilityInfo
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
