[mapserver-users] Which Java JDK?
Grant Marblestone GrantM at ATSER.com
Wed Jan 23 14:07:08 EST 2002
>From what i understand the 1.3 will auto download the version you need to
run.  But java is supposedly write once run anywhere... and this too should
be backwards compatible.
Grant
----- Original Message -----
To: <fgclaram at alu-ab.uclm.es>; <mapserver-users at lists.gis.umn.edu>;
<woodbri at swoodbridge.com>
Sent: Wednesday, January 23, 2002 11:11 AM
Subject: Re: [mapserver-users] Which Java JDK?
> With 1.3 won't you need a plugin to run the applet though?
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> Francisco <fgclaram at alu-ab.uclm.es> 01/23/02 11:00AM >>>
> Hello.
> You can get JDK 1.3.x and you will not have problems (I suppose).
> You can download from http://java.sun.com/j2se/1.3/download-linux.html
> Regards,
> Fran.
> At 09.47 23/1/02 -0500, Stephen Woodbridge wrote:
> >Sorry, if this is a little off topic.
> >I want to get a Java JDK for my RedHat 6.2 Linux box so I can try and
> >make some changes to the Rosa applet. I want the applet to run in the
> >existing browsers.
> >Which Java JDK should I get?
> >Do I need to worry about Java 1 vs Java 2?
> >Where should I get it from?
> >Thanks for any help you can offer,
> >   -Steve
