[mapserver-users] Free Map Symbols
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Wed Jan 23 16:44:17 EST 2002
Yes I would very much like to see these, since the issue of map symbols
has come up I would like to ask a question:
I am drawing a triange symbol, an example is given for this on:
http://mapserver.gis.umn.edu/symbolset.html#line
it goes like this:
points: Signifies the start of the definition of points that make up a
vector symbol or that define the x and y radius of an ellipse
symbol. Here's an example that defines a simple triangle vector
symbol:
POINTS
0 4
2 0
4 4
0 4
END
If you draw a line through these points you get an inverted triangle, but
it draws a normal triangle. (Even if you go up from bottom to up you get
the same results)
I tried the following and got an inverted triangle!
0 0
1 1
2 0
0 0
Can anybody explain the logic behind this?
Thanks,
> Does anyone have a good resource for free cartographic map symbols that can
> be used w/ mapserver?
> Kind regards,-matt
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
