[mapserver-users] Apache webserver 1.3 (FWD)
PARVILLERS
hugues at parvillers.com
Mon Jan 28 17:45:15 EST 2002
Should I add to Annie that if you use only relative paths for your aliases (for
example where image are written) then the root is usually htdocs.
Hugues
"Morin, Annie" a écrit :
> When you call your mapfile, do you give the entire physical path? ex:
> mapserv?map=c:\directory\to\my\map\file.map
> because this is not Apache or IIS that manages the mapfile but mapserver.
> and maybe a space in the physical path may cause trouble... just as:
> c:\program files\directory_to_myFile\file.map
> and maybe on 2000, this is your security process which deny access to a file
> in a specific directory. When you have a http connection onto your server,
> the user requesting the map file, does he have the access privileges?
> It can be several of these that can cause your problem problem.
> Annie Morin
> > De : teb[SMTP:teb at mallit.fr.umn.edu]
> > Répondre à : teb
> > Date : 28 janvier, 2002 15:35
> > A : mapserver-users at lists.gis.umn.edu
> > Cc : blaine at plansight.com
> > Objet : [mapserver-users] Apache webserver 1.3 (FWD)
> > ------------- Begin Forwarded Message -------------
> > From: "Blaine Hackett" <blaine at plansight.com>
> > To: <mapserver-info at lists.gis.umn.edu>
> > Subject: Apache webserver 1.3
> > Date: Mon, 28 Jan 2002 11:49:38 -0600
> > MIME-Version: 1.0
> > Content-Transfer-Encoding: 7bit
> > X-Priority: 3 (Normal)
> > X-MSMail-Priority: Normal
> > Importance: Normal
> > X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4133.2400
> > All
> > I have implemented mapserver on 2000 with IIS. It works
> > fine. I have installed Apache 1.3 on another computer for
> > testing. Now it can not find the map file. It gives me
> > the old "msLoadMap(): Unable to access file.". Does anyone
> > know how apache treats its relative paths?
> > Blaine
> > Blaine Hackett
> > GIS Project Manager
> > PlanSight LLC
> > 651.653.5141
> > ------------- End Forwarded Message -------------
