[mapserver-users] Strage behaviour of dynamic classes (color v/s
outlinecolor)
Daniel Morissette
morissette at dmsolutions.ca
Tue Jan 29 07:09:49 EST 2002
Vinko Vrsalovic wrote:
> I'm creating layers according to some user input, the layers
> are drawn, but the polygon layers take the color parameter
> as the outline color and the color inside the polygons remain
> always the same as the background color of the image.
Based on this description, it looks very much like your polygon layer is
drawn as a polyline layer...
> $lay[$layers[$i]]->set("type","MS_LAYER_".$data["tipo"][$i]);
Passing "MS_LAYER_POLYGON" as a string doesn't have the same meaning as
passing a constant of MS_LAYER_POLYGON. Try this:
if ($data["tipo"][$i] == "POLYGON")
$lay[$layers[$i]]->set("type", MS_LAYER_POLYGON);
else if (...
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
