[mapserver-users] Another question
Morin, Annie amorin at NRCan.gc.ca
Tue Jan 29 14:39:29 EST 2002
here is an example on how I do it. give me news if it worked.
Annie Morin
LAYER
	NAME "14"
	TYPE Point
	STATUS ON
	DATA phot250
	QUERY
		TEMPLATE "d:\www\moosemon\module_map\out.html"
	END #  QUERY
	CLASS
		symbol ellipse1
		size 6
		Name 'Photo_250mm'
		COLOR 255 0 0
		OUTLINECOLOR 0 0 0
	END  # CLASS
END  # LAYER
we do a query by calling a template file (out.html)
which contains
document.location =
"/geoide/Module_map/Component_info/info_frames.cfm?LayerName=[DATASET_ID]&Ke
yString=[SP_OBJ_ID]&source_id=[SOURCE_ID]&data=[MSLINK_ODB]&X=[X]&Y=[Y]";
[DATASET_ID], [SP_OBJ_ID],[SOURCE_ID] and  [MS_LINK_ODB] are columns in our
dbf of the shapefile.
Annie Morin
> De : 	Nacho Benito[SMTP:nachobenito75 at hotmail.com]
> Date :	29 janvier, 2002 14:14
> A :	mapserver-users at lists.gis.umn.edu
> Objet :	[mapserver-users] Another  question
> hello,
> I'm sorry to ask again now I would like to know how can I define a query
> layer (I want to do an itemquery). I suposse I'm not doing it well because
> when I try to execute the code mapserv answer:
> No query layer defined
> Could anyone help me?
> Thank you
> Nacho
> _________________________________________________________________
> Descargue GRATUITAMENTE MSN Explorer en
> http://explorer.yupimsn.com/intl.asp
