[mapserver-users] Masperver with postgis on windows2000
Pericles S. Nacionales
pnaciona at gis.umn.edu
Tue Jan 29 16:58:57 EST 2002
Nicolas, folks,
After much putzing around with PostGIS support on Windows (and not using
Cygwin), I finally successfully produced executable that seem to work. I
said "seem" because I really haven't tried it yet. However, a quick version
check gives me this:
MapServer version 3.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PRO
J SUPPORTS=TTF INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
If anyone is interested, I've packaged the the binaries into a zip file
which can be downloaded at
http://128.101.73.155/projects/ms35_gdal_ogr_pg.zip. Please let me know if
it works, or not.
I'll provide a compile how-to, once I iron out any kinks.
-Perry N.
> -----Original Message-----
> From: owner-mapserver-users at lists [mailto:owner-mapserver-users at lists]On
> Behalf Of jrom
> Sent: Tuesday, January 29, 2002 8:41 AM
> To: mapserver-users at lists
> Subject: [mapserver-users] Masperver with postgis on windows2000
> Hello,
> For about 4 months, we develop application based on
> PostgreSQL/Postgis/Mapserver.
> It works just fine on our linux servers.
> For demo purpose, I need to install all this on a windows2000 laptop.
> On my Windows NT machine, PostgreSQL/Postgis is running fine in a cygwin
> env. I've compiled MS 3.5 for postgis, and can access postgis tables,
> from either a local DB, or a remote one on a linux server.
> I try to do the same thing on the laptop: Postgis is running, but I
> can't use mapserver 3.5:
> The binaries available on the mapserver site are not compiled for
> postgis, as far as I saw ("postgis symbol declared but not defined")
> I try to use the mapserv.exe I compiled for NT: it does not work (apache
> says: "premature end of script hearders".
> I recompile mapserv (./configure --with-postgis) on windows2000, in a
> cygwin environment. Same apache error message.
> So, I write to you to have a little help:
> Do you know any restriction by using MS 3.5 with postgis on windows2000?
> Is it possible to have the windows binaries for MS 3.5 compiled for
> postgis or to have the settings used to compile the binaries for windows ?
> Thank you very much
> Nicolas Ribot
> SCOT
