[mapserver-users] tiff problem,
David Graham
dgraham at i3.com
Thu Jan 31 11:06:55 EST 2002
Pushkar Pradhan wrote:
>I've tried giving absolute paths in the DATA field but it gives me Internal
>Server Error.
>The TIFs are GEOTIFFS,
>Do I need to have projection support enabled to display GEOTIFFs, sorry I
>am not experienced in GIS field. Thanks,
Good Question. I am not sure. Here we compiled it to run with the GDAL
library (www.remotesensing.org) and have been using that to read both
GEOTIFF and regular TIFF's with ESRI world files. I have not tried to
use it with the straight tifflib.
My guess is that you do not have geotiff capablility. I am not sure how
Mapserver without GDAL deals with this. It might require an ESRI world
file. See if you can find a tool that will export the geotiff tags to
an ESRI world file with the same name and a .tfw extension. Then place
the world file in the same directory as the Tiff imagery. Or ask
someone more knowlegable than me.
Any help out there?
Dave Graham
