[mapserver-users] About "complete" Makefile.vc for MapServer 3.6.1 (and about ECW)
Pericles S. Nacionales pnaciona at gis.umn.edu
Mon Jul 1 01:56:10 EDT 2002
Hisaji,
Use the extension ".wld" for your world files (so you'll have a world
file called 533915.wld).  MapServer requires this as the world file
extension, regardless of what raster format you use.  Check
http://mapserver.gis.umn.edu/doc36/raster-howto.html#world_files for
more info.
I don't use ECW-compressed images so I can't help you with ECW-specific
questions but there are probably a few people out there using it with
MapServer.
Good luck!
Perry N.
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of Hisaji ONO
Sent: Saturday, June 29, 2002 10:39 AM
To: Pericles S. Nacionales
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] About "complete" Makefile.vc for
 Thank you very much for your help, Mr. Nacionales.
 I could make MapServer 3.6.1 with WMSClient.
 And this is another question about ECW. I tried my compiled MapServer
3.6.1
and pre-build 3.6 to display ECW image(8 bit) with following map file.
NAME rasterex
EXTENT 139.6 35.4 139.75 35.5
SIZE 512 512
SHAPEPATH "d:\MapServ\map"
UNITS DD
#WEB
# IMAGEPATH "C:\Program Files\Apache Group\Apache\htdocs\tmp\"
# IMAGEURL "/tmp/"
#END
LAYER # start of the "yokohama" layer object
  NAME "yokohama image"
  DATA "533915.ecw"
  TYPE RASTER
  STATUS DEFAULT
END # end of layer object
END # end of map file
 But nothing diplayed without error messages.
 ECW doesn't requre World File? Without world file(.eww?), shp2img.exe
didn't show error message and created blank images.
 Do you have any suggestion.
 Best Regards.
