[mapserver-users] RE: reference map changes to cross-hair when map extent became small
Julien-Samuel Lacroix lacroix at dmsolutions.ca
Tue Jul 2 09:01:57 EDT 2002
Here's the new reference map options.
MARKER works like the SYMBOL keyword in the CLASS. It's the MARKER use in
your reference map when the bounding box is to small (lower than
MINBOXSIZE).
Default is the cross-hair.
MARKERSIZE is the size of the MARKER. Works like the SIZE in CLASS.
MINBOXSIZE is the min size of the bounding box. At this size or lower, the
cross-hair (or any MARKER specified) will be used. Use an integer value.
Default value is 3.
MAXBOXSIZE is the max size of the bounding box. Bigger than that,
nothing will
be draw. This option is really usefull when the bounding box is bigger
than the
reference map and does not appear on the reference map, you can prevent
mapserver from drawing a bounding box outside the reference map.
Julien
YC Nyon wrote:
>i remember that with version 3.6, there is a option to specify a
>cross-hair/dot in place of a red bounding box when
>the map extent became small. However, i can't seem to find it in the map
>file documentation.
>Anyone can help?
>Thanks
>Nyon
