[mapserver-users] mapserver and mod_perl hybrid
Lowell.Filak
lfilak at medinaco.org
Tue Jul 2 12:23:03 EDT 2002
There are users on the list that are using mod_perl & mapscript and I
suspect you will hear from them. The only issue that has come up so far
is:
http://mapserver.gis.umn.edu/wilma/mapserver-users/0205/msg00088.html
You will find a quick-fix there that seems to have solved the issue(s) for
now. You will also find the reply from Steve in regards to the future
plans to resolve any issues for the long-term.
Lowell F.
On Tue, 2 Jul 2002, Markus Spring wrote:
> Hi list,
> I am using mod_perl and mapserver in a hybrid environment: pre- and
> postprocessing form data and html as well as coupling mysql data with
> mapserver queries.
> Having not dared to switch to mapscript for the generation of the
> maps, I do this in a hybrid way by running the mapserver executable
> from inside the mod_perl apache server.
> This is a very stable solution which gives me complete freedom over my
> html and sql database but maybe it is not the most performant way to
> achieve my goals.
> I would like to know if anybody does use mod_perl and mapscript to for
> mapserver purposes and if there are any pitfalls to avoid.
> Markus
