[mapserver-users] proj4 and path configuration
Steven Bowden
steveb at bundaberg.qld.gov.au
Wed Jul 3 18:37:38 EDT 2002
Make sure that /usr/local/lib is in your /etc/ld.so.conf directory
and then make sure you run ldconfig as root to update all the library
paths. This is for a RedHat system so it may vary depending on your
system.
Steve
On Wed, 2002-07-03 at 20:34, Cedric BERNIER wrote:
Hi all!
I've decided to use the --with-proj option in config the re-install mapserv.
I have a problem when I start mapserv .
my navigator displays an internal error.
the /var/log/httpd/error_log says :
mapserv:error while loading libraries:libproj.so.0 cannot open shared object
file : No such file or directory.
certainly a PATH misconfiguration ...
this lib is installed in my /usr/local/lib.
Is there anything to configure like an environment variable or something like
that ?
Thanks for your help.
Have a nice independance day.
CB.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020704/c0eddb3b/attachment.html
