[mapserver-users] Can't figure out queries with Mapscript.
Ben Logan ben at wblogan.net
Thu Jul 4 07:35:01 EDT 2002
Well, I'm sure I'm missing something simple here because I see other
people making queries work, but I simply can't figure it out.
I am using Mapserver 3.6.1 and PHP 4.0.6 on Redhat 7.1.  PHP is
running as a CGI (thanks to David Norris for help with that).
The only way I can see to make use of the results of a query, is to
create a template that contains some PHP code which I can then
evaluate.  To test things out, I created a simple template called
county.php which contains the following lines:
$county = "[COUNTY]";
$state = "[STATE]";
echo "$county\n$state\n";
(COUNTY and STATE are fields in the dbf file.)
In my map file, I have tried adding a
TEMPLATE "county.php"
line in the CLASS definition I'm querying.  (I have also tried using
the full path to county.php.)  When I call processQueryTemplate(), it
returns nothing.  So I tried moving the TEMPLATE line into the LAYER
definition, but that didn't work either.  The layer gets queried,
because the county I click is highlited in the query map.  Of course,
I realize that the data which processQueryTemplate() returns will need
to be parsed by PHP in order for the variables to be set, but I can't
get the function to return anything at all.
I found a message in the list archives that said that TEMPLATE defs
needed to be contained inside QUERY defs.  Like this
QUERY
	TEMPLATE dummy
END
I tried that in both the LAYER and CLASS sections, but either way
Mapscript gives a fatal error parsing the map file.
Am I going about this all wrong?  Even if this isn't the way to get
the query data, why can't I get templates to work?
One other thing: I had METADATA definitions in my LAYER sections that
looked like this
METADATA
	title "My Layer Title"
END
I was using these to define layer titles that Mapscript could use, and
it was working with Mapserver 3.5.  In 3.6.1, I had to comment all of
the defs out, because it wouldn't parse the map file.  Can anyone tell
me why?
I would really appreciate any help with these problems (especially the
querying problems).  I have included my map file and my php script
below.  They are both terrible messes because I've been using them to
get a feel for Mapscript.
Thanks,
Ben
Ben Logan: ben at wblogan dot net
OpenPGP Key KeyID: A1ADD1F0
So many women; so little nerve.
----------php.map-----------
# Start of map file
NAME TEST
STATUS ON
SIZE 400 400
#EXTENT -80.633987 36.708718 -80.104413 37.123488
EXTENT -81.379427 36.542485 -80.041493 37.366792
UNITS DD
#SHAPEPATH "data"
IMAGECOLOR 255 255 255
FONTSET "/var/www/html/ben/mapserv_demo/test/fonts"
#PROJECTION
#	"proj=latlong"
#	"datum=NAD83"
#END
# you may need to change this to match your MapServer build
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter discussion
#PROJECTION
#  "proj=utm"
#  "ellps=GRS80"
#  "zone=15"
#  "north"
#  "no_defs"
#  OR:
#  "init=epsg:26915"
#END
# Start of web interface definition (including WMS enabling metadata)
WEB
  #HEADER test_header.html
  #TEMPLATE county.php
  #FOOTER test_footer.html
	LOG "/var/www/html/ben/mapserv_demo/local/test.log"
  MINSCALE 1
  MAXSCALE 2000000
  IMAGEPATH "/var/www/html/ben/mapserv_demo/local/tmp/"
  IMAGEURL "http://mach1/ben/mapserv_demo/local/tmp/"
  METADATA
    WMS_TITLE "A test map."
    WMS_ABSTRACT "This is a test."
    WMS_ACCESSCONSTRAINTS none
    # change this value to match your setup
    WMS_ONLINERESOURCE "http://mach1.log.cabin/ben/mapserv_demo/local/test_init.html"
    WMS_SRS "EPSG:26915"
  END
END
# Start of reference map
#REFERENCE
#  IMAGE 'graphics/ref.png'
#	EXTENT -80.633987 36.708718 -80.104413 37.123488
#  SIZE 200 200
#  STATUS ON
#  COLOR -1 -1 -1
#  OUTLINECOLOR 255 0 0
#END
# Start of legend
LEGEND
  KEYSIZE 18 12
  LABEL
    TYPE BITMAP
    SIZE MEDIUM
    COLOR 0 0 89
  END
  STATUS ON
END
# Start of scalebar
SCALEBAR
  LABEL
    COLOR 0 255 0
    SIZE tiny
  END
  STYLE 1
  SIZE 80 2
  COLOR 0 0 255
  UNITS MILES
  INTERVALS 1
  TRANSPARENT TRUE
  STATUS TRUE
END
# Start of symbol definitions (we're only using a few)
# Start of layer definitions
LAYER
  NAME "County"
  TYPE POLYGON
  STATUS DEFAULT
	TEMPLATE /var/www/html/ben/mapserv_demo/local/county.php
	#DATA "tgr51063cty00"
  TILEINDEX "/var/www/html/ben/mapserv_demo/local/county.shp"
	TILEITEM "location"
	DATA "county"
	#HEADER "test_header.html"
	#FOOTER "test_footer.html"
	#METADATA
	#	title "County Boundaries"
	#END
  CLASS
		NAME "County"
    OUTLINECOLOR 0 0 0
    COLOR 255 255 200
  END
END
#LAYER
#	NAME "Relief"
#	TYPE RASTER
#	STATUS DEFAULT
#	DATA "floyd.tif"
#	#PROJECTION
#	#	"proj=utm"
#	#	"ellps=WGS84"
#	#	"zone=17"
#	#	"north"
#	#	"no_defs"
#	#END
#END
#LAYER
#  NAME "lpy"
#  TYPE POLYGON
#  STATUS OFF
##	CONNECTIONTYPE OGR
##	CONNECTION "data/carroll, 0"
#	DATA "tgr51063lpy"
#  #CLASSITEM 'STATES'
#  CLASS
#		NAME "LandmarkPoly"
#    OUTLINECOLOR 0 0 255
#    #COLOR 255 255 200
#  END
#END
LAYER
  NAME "Places"
  TYPE POLYGON
  STATUS OFF
	TILEINDEX "/var/www/html/ben/mapserv_demo/local/plc00.shp"
	TILEITEM "location"
	LABELITEM "NAME"
	DATA "plc00"
	LABELMAXSCALE 500000
  #METADATA
	#	title "Designated Places"
	#END
  CLASS
		NAME "Places"
    OUTLINECOLOR 0 255 255
    COLOR 240 240 180
    LABEL
      MINDISTANCE 150
      POSITION AUTO
      SIZE 9
			TYPE truetype
			FONT "arial"
      COLOR 0 0 0
    END
  END
END
LAYER
  NAME "majroads"
  TYPE LINE
  STATUS OFF
  TILEINDEX "/var/www/html/ben/mapserv_demo/local/majroads.shp"
	TILEITEM "location"
	DATA "majroads"
	LABELITEM "RTE_NUM"
  #METADATA
	#	title "Major Roads"
	#END
  #CLASSITEM 'STATES'
  CLASS
		NAME "Major Roads"
    OUTLINECOLOR 0 0 0
    COLOR 255 0 0
		#TEMPLATE "majroads.html"
    LABEL
			#ANGLE AUTO
      #MINFEATURESIZE 40
      MINDISTANCE 150
      POSITION AUTO
			#BACKGROUNDCOLOR 255 255 255
			#BACKGROUNDSHADOWCOLOR 80 80 80
			#OUTLINECOLOR 0 0 0
			#BUFFER 2
      SIZE 8
			TYPE truetype
			FONT "arial"
      COLOR 0 0 0
    END
  END
END
LAYER
  NAME "minroads"
  TYPE LINE
  STATUS OFF
	TILEINDEX "/var/www/html/ben/mapserv_demo/local/minroads.shp"
	TILEITEM "location"
	DATA "minroads"
	LABELITEM "NAME"
	LABELMAXSCALE 200000
  #METADATA
	#	title "Minor Roads"
	#END
  CLASS
		NAME "Minor Roads"
    OUTLINECOLOR 0 0 0
    COLOR 0 255 0
		#TEMPLATE "minroads.html"
    LABEL
			#ANGLE AUTO
      #MINFEATURESIZE 40
      MINDISTANCE 150
      POSITION AUTO
			#OUTLINECOLOR 255 255 255
			#BUFFER 2
      SIZE 8
			TYPE truetype
			FONT "arial"
      COLOR 0 0 0
    END
  END
END
QUERYMAP
  STATUS ON
  STYLE HILITE
  COLOR 0 255 255
END
END # Map File
----------test.pmap-----------
dl("php_mapscript.so");
function getLayerTitle($layerObj) {
	# If the layer passed has a metadata string named "title," it will be
	# returned.  Otherwise, the name of the layer will be returned.
	$title = $layerObj->getMetaData("title");
	if($title == "") {
		$title = $layerObj->name;
	return $title;
function pixelToGeo($map,$x,$y) {
	# Convert x,y pixel values to georeferenced coords.  Returns a
	# pointObj.
	$minx = $map->extent->minx;
	$miny = $map->extent->miny;
	$maxx = $map->extent->maxx;
	$maxy = $map->extent->maxy;
	$dx = $maxx - $minx;
	$dy = $maxy - $miny;
	$width = $map->width;
	$height = $map->height;
	$dxpp = (double)$dx/$width;
	$dypp = (double)$dy/$height;
	$geox = $minx + $dxpp*$x;
	$geoy = $maxy - $dypp*$y;
	$pointObj = ms_newPointObj();
	$pointObj->setXY($geox,$geoy);
	return $pointObj;
$val_zsize = 3;
$check_pan = "CHECKED";
$map_path = "/var/www/html/ben/mapserv_demo/local/";
$map_file = "php.map";
$layer_chkbtn_name = "layers";
$map = ms_newMapObj($map_path.$map_file);
if(isset($HTTP_POST_VARS["update"]) || (isset($HTTP_POST_VARS["mapa_x"]) && isset($HTTP_POST_VARS["mapa_y"])
	&& !isset($HTTP_POST_VARS["full"])) ) {
	$extent_to_set = explode(" ",$HTTP_POST_VARS["extent"]);
	$map->setextent($extent_to_set[0], $extent_to_set[1], $extent_to_set[2], $extent_to_set[3]);
	$my_point = ms_newpointObj();
	$my_point->setXY($HTTP_POST_VARS["mapa_x"],$HTTP_POST_VARS["mapa_y"]);
	$my_extent = ms_newrectObj();
	$my_extent->setextent($extent_to_set[0], $extent_to_set[1], $extent_to_set[2], $extent_to_set[3]);
	if($HTTP_POST_VARS["zoom"] == 2) {
		# Query
		$zoom_factor = 1;
		$check_pan = "";
		$check_zout = "";
		$check_zin = "";
		$check_query = "CHECKED";
		$res = $map->queryByPoint(pixelToGeo($map,$HTTP_POST_VARS["mapa_x"],$HTTP_POST_VARS["mapa_y"]),MS_SINGLE,0);
		if($res == MS_SUCCESS) {
			# Draw a query map
			$q_image = $map->drawQuery();
			# Save the map.
			$q_url = $q_image->saveWebImage(MS_PNG,1,1,0);
			$query_res = $map->processQueryTemplate(array());
	} else {
		$zoom_factor = $HTTP_POST_VARS["zoom"]*$HTTP_POST_VARS["zsize"];
		if($zoom_factor == 0) {
			$zoom_factor = 1;
			$check_zout = "";
			$check_zin = "";
			$check_query = "";
		} else if ($zoom_factor < 0) {
			$check_pan = "";
			$check_zout = "CHECKED";
			$check_zin = "";
			$check_query = "";
		} else {
			$check_pan = "";
			$check_zout = "";
			$check_zin = "CHECKED";
			$check_query = "";
	$val_zsize = abs($zoom_factor);
	if(isset($HTTP_POST_VARS["mapa_x"]) && isset($HTTP_POST_VARS["mapa_y"]) && !($HTTP_POST_VARS["zoom"] == "2")) {
		$map->zoompoint($zoom_factor,$my_point,$map->width,$map->height,$my_extent);
$image = $map->draw();
if(is_array($HTTP_POST_VARS[$layer_chkbtn_name])) {
	# Turn on the necessary layers
	$layers = $HTTP_POST_VARS[$layer_chkbtn_name];
	foreach($layers as $layer) {
		$l = $map->getLayer($layer);
		$l->set("status",MS_ON);
		$l->draw($image);
$map->embedScalebar($image);
$map->drawLabelCache($image);
$image_url = $image->saveWebImage(MS_PNG, 1, 1, 0);
$extent_to_html = $map->extent->minx." ".$map->extent->miny." ".$map->extent->maxx." ".$map->extent->maxy;
# Draw the legend.
$legend_image = $map->drawLegend();
$legend_url = $legend_image->saveWebImage(MS_PNG, 1, 1, 0);
<html>
<head>
<title>Testing</title>
</head>
<body>
<center>
<form method=POST action=<? echo $PHP_SELF ?>>
<table>
	<tr>
		<td colspan=2 align=center>
			<input type=image name="mapa" src="<? echo $image_url ?>">
		</td>
	</tr>
	<tr>
			<img src="<?echo $legend_url ?>" alt="Legend">
		</td>
	</tr>
	<tr>
		<td>
			Pan
		</td>
		<td>
			<input type=radio name="zoom" value=0 <? echo $check_pan ?>>
		</td>
	</tr>
	<tr>
		<td>
			Zoom In
		</td>
		<td>
			<input type=radio name="zoom" value=1 <? echo $check_zin ?>>
		</td>
	</tr>
	<tr>
		<td>
			Zoom Out
		</td>
		<td>
			<input type=radio name="zoom" value=-1 <? echo $check_zout ?>>
		</td>
	</tr>
	<tr>
		<td>
			Query
		</td>
		<td>
			<input type=radio name="zoom" value=2 <? echo $check_query ?>>
		</td>
	</tr>
	<tr>
		<td>
			Zoom Size
		</td>
		<td>
			<input type=text name="zsize" value="<? echo $val_zsize ?>" size=2>
		</td>
	</tr>
	<tr>
		<td>
			Full Extent
		</td>
		<td>
			<input type=submit name="full" value="Go" size=2>
		</td>
	</tr>
	<tr>
		<td colspan=2>
			# Here we print the checkboxes for the layers.
			for($i=0; $i<$map->numlayers; $i++) {
				# Get the layerObj.
				$l = $map->getLayer($i);
				# If the layer has Default status, don't display it.
				if( $l->status == MS_DEFAULT ) {
					continue;
				# Otherwise, we'll print an html form element.
				$chk = "";
				if( $l->status == MS_ON ) {
					$chk = "checked";
				$layerTitle = getLayerTitle($l);
				print("<input type=\"checkbox\" name=\"".$layer_chkbtn_name."[]\" value=$i $chk>$layerTitle<br>\n");
		</td>
	</tr>
	<tr>
		<td colspan=2>
			<input type=submit name="update" value="Update">
		</td>
	</tr>
if(isset($q_url)) {
	<tr>
		<td colspan=2>
			<img src="<? echo $q_url ?>">
		</td>
	</tr>
</table>
<input type=hidden name="extent" value="<? echo $extent_to_html ?>" >
</form>
</center>
<pre>
printf("minx: %f\nminy: %f\nmaxx: %f\nmaxy: %f\n",$map->extent->minx,$map->extent->miny,$map->extent->maxx,$map->extent->maxy);
printf("width: %d\nheight: %d\n",$map->width,$map->height);
printf("Lat/pixel: %f\n",($map->extent->maxy - $map->extent->miny)/$map->height);
printf("Long/pixel: %f\n",($map->extent->maxx - $map->extent->minx)/$map->width);
print("Buffer: ".$query_res);
</pre>
</body>
</html>
