[mapserver-users] antialias
Seamus Thomas Carroll carrolls at unbc.ca
Sat Jul 6 00:23:57 EDT 2002
Thanks problem solved.
Do you know how I obtain fonts so I can point my fontset path to the
correct direction?
Seamus
On Fri, 5 Jul 2002 woodbri at swoodbridge.com wrote:
> Seamus,
> If you are using Mapserver 3.5+ then you must use
> ANTIALIAS TRUE
> -Steve
> On 5 Jul 2002 at 18:29, Seamus Thomas Carroll wrote:
> > When a try to use antialias in the map file I recieve the error
> > "getSymbol(): Symbol definition error. (FONT):(23)".  Any suggestions on
> > what the problem might be?  Below is its use in the map file:
> > 	LEGEND
> > 		STATUS ON
> > 		LABEL
> > 			TYPE TRUETYPE
> > 			ANTIALIAS
> > 			FONT arial
> > 			COLOR 0 0 0
> > 			SIZE 12
> > 		END
> > 	END
> > Seamus
