[mapserver-users] Labeling Rules -- spatial priority
woodbri at swoodbridge.com woodbri at swoodbridge.com
Sun Jul 7 12:20:30 EDT 2002
On 7 Jul 2002 at 11:01, S&K Lehr wrote:
> Good morning. I've got somedata exported from InfoCad which is
> point information with text and an angle (specifically its a parcel
> dimension layer). The data seems to be triplicated (three records of
> the same data--though sometime moreor less), unfortunately the data
> is not directly ontop of one another but slightly off set.
> The data in the .dbf file is notsequential, so its not realistic to
> just null out the text label in sequential passess of the data.
There is a shpsort utility floating about that might let you sort the
data based on an attribute, but I don't remember where I saw it.
> Does mapserver have anyway to use a first come first label, so that
> it wont look triple typed. i.e. if a label already occupies the
> space, it will only get one label?
Yes, if you set MINDISTANCE <pixels> in your LABEL definition then it
will not place another label with the same name within <pixels>
distance of the first one placed.
-Steve
