[mapserver-users] Display contour map on Mapsever
randy james rjames57 at yahoo.com
Mon Jul 8 12:11:32 EDT 2002
Hi
I imagine it is possible using mapscript but i'm not
up to speed with it yet. If you can execute commands
from input by the user with mapscript it would work.
The GRASS module, r.contour would be able to generate
contours, but you would need the help of someone who
can write mapscript, to be able to do it dynamically.
I hope to be able to do it also someday when i have
time. As i would like the users to use the system to
model ecosystems.
Randy
--- Hisaji ONO <hi-ono at mn.xdsl.ne.jp> wrote:
>  Thank you for your response, Mr. James.
> Could you tell me any idea of dynamically generating
> countour mas when some
> user's points with attribute data are put.
>  Regards.
> ----- Original Message -----
> From: "randy james" <rjames57 at yahoo.com>
> To: "Hisaji ONO" <hi-ono at mn.xdsl.ne.jp>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Tuesday, July 09, 2002 12:47 AM
> Subject: Re: [mapserver-users] Display contour map
> on Mapsever
> > Hi
> > I've used GRASS with great success, for generating
> > contours from an DEM. Check out.
> >  http://www3.baylor.edu/grass/index2.html
__________________________________________________
Do You Yahoo!?
Sign up for SBC Yahoo! Dial - First Month Free
http://sbc.yahoo.com
