[mapserver-users] addfeature - point appearing at center of map?
Debbie Pagurek
pagurekd at agr.gc.ca
Tue Jul 9 14:36:14 EDT 2002
I have created an application that adds points to the map "on-the-fly". It makes use of a layer outlined as follows in the map file:
LAYER
NAME COLLECTIONS
TYPE POINT
FEATURE
END
STATUS ON
TEMPLATE VOID
CLASS
SYMBOL "circle"
SIZE 5
COLOR 255 0 0
END
PROJECTION
"init=epsg:4326"
END
END
For some reason, in addition to the points I am adding dynamically using php/mapscript, there is a point showing at the very centre of the map (the map is 600 by 300, so the point is appearing at 300, 150) or a point is appearing at 0 lat, 0 long even though I have NOT coded this at all. I can't figure out how to get rid of this point on my maps!
here's a bit of code:
// loop through records and display (addfeature) each point
$dummylayer=ms_newLayerObj($map); //a new layerobject
$numrows = count($long);
for ($i = 0 ; $i <= $numrows; ++$i)
$oShp=ms_newShapeObj(MS_SHP_POINT);
$oLine=ms_newLineObj();
$oLine->addXY($long[$i],$lat[$i]);
$oShp->add($oLine);
$dummylayer=$map->getLayerByName("COLLECTIONS");
$dummylayer->addfeature($oShp);
Anyone have any ideas why this point is appearing in the centre?
Thanks,
D. Pagurek
