[mapserver-users] Python Mapscript MS 3.6.1
Vinko Vrsalovic
vinko at cprsig.cl
Wed Jul 10 16:06:29 EDT 2002
Hello,
I've been trying to compile the mapscript python module, but I
keep finding this errors:
First, when swigging the .i file, i get:
swig -python -shadow -DSWIGPYTHON -module mapscript -o
./mapscript_wrap.c ../mapscript.i
../mapscript.i:37. Warning: class keyword used, but not in C++
mode.
../../map.h:424. Warning: class keyword used, but not in C++
mode.
/usr/lib/swig1.3/constraints.i:89. Warning. Deprecated typemap
feature ($source/$target).
swig: The use of $source and $target in a typemap declaration
is deprecated.
swig: For typemaps related to argument input
(in,ignore,default,arginit,check), replace
swig: $source by $input and $target by $1. For typemaps
related to return values (out,
swig: argout,ret,except), replace $source by $1 and $target by
$result. See the file
swig: Doc/Manual/Typemaps.html for complete details.
/usr/lib/swig1.3/constraints.i:108. Warning. Deprecated
typemap feature ($source/$target).
That warning goes on for several lines.
Later, when compiling the mapscript_wrap.c, i get:
gcc -DNDEBUG -O3 -fomit-frame-pointer -pipe -mcpu=pentiumpro
-march=i586 -ffast-math -fno-strength-reduce -fPIC -UTIFF_STATIC
-UJPEG_STATIC -UZLIB_STATIC -UIGNORE_MISSING_DATA -UUSE_EPPL
-UUSE_PROJ -UUSE_PROJ_API_H -UUSE_WMS -UUSE_TIFF -UUSE_JPEG
-UUSE_GD_PNG -UUSE_GD_JPEG -UUSE_GD_WBMP -UUSE_GDAL
-UUSE_POSTGIS -I../.. -I../../gd-1.8.4
-I/usr/local/include/freetype -I/usr/local/include
-I/usr/include/python2.2 -c mapscript_wrap.c -o
build/temp.linux-i686-2.2/mapscript_wrap.o
mapscript_wrap.c: In function `_raise_ms_exception':
mapscript_wrap.c:1583: `ms_error' undeclared (first use in this
function)
mapscript_wrap.c:1583: (Each undeclared identifier is reported
only once
mapscript_wrap.c:1583: for each function it appears in.)
I've read the archives and found references to this error, but
then i get only: OK, now i solved that and built the extension,
and I have another problem, but they don't tell how did they
solve the error :-(
I've tried to use the Vines's setup.py script, but that doesn't
solve the compilations problem nor the swig warnings...
Python 2.2, Swig 1.3.
Any and all help will be greatly appreciated.
Vinko Vrsalovic <vinko[|- at -|]cprsig.cl>
http://www.cprsig.cl
