[mapserver-users] scaling labels
Steve Lime
steve.lime at dnr.state.mn.us
Wed Jul 10 17:24:18 EDT 2002
I'm not sure what you're asking in 1. A shape belongs to the first class
it matches, period. I think you'll need to draw the shapefile in
question (perhaps once as an annotation layer) to get the effect you're
after.
On 2. you've neglected to define a SIZE for the label. Default it
probably a GD constant for bitmap fonts (1 or something like that). Also
note that you won't get any scaling unless you define a value for
SYMBOLSCALE.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Alexander Shostko <shostko at ureach.com> 07/09/02 11:49PM >>>
Dear Mapserver Users!
Thanks in advance for reading this message and for all possible
hints and suggestions.
1. how can I make the class transparent (so other classes can
set the color on the same shapes)in the same layer ?
e.g.
class
expression( [level] lt 3.0 )
# should be transparent, but allow other class to set the
color. Only labels should be defined
label
end
end
class
expression ( [perimeter] > 3.0 )
color 23 23 23
outlinecolor 0 0 0
end
2. I use labeling based on the attributes (mapserver v 3.6 GIF
version) and use CGI only. However it uses
bitmap fonts and they do not scale at all. If I put 'type
truetype, then no labels is shown at all. What can be
the possible reason.
The layer looks like:
layer
classitem 'STATE'
data "statesp020"
group "statesp020"
labelcache on
labelitem 'STATE'
name "statesp020"
postlabelcache true
status on
type polygon
# red
class
EXPRESSION ( [LEVEL] ge 9.0 )
color 255 0 0
outlinecolor 72 61 139
TEXT( [STATE] )
label
position auto
font arial
minsize 10
maxsize 30
mindistance 100
buffer 100
force true
color 0 0 0
end
end
# 1 class statesp020_1
class
EXPRESSION ( [LEVEL] lt 2.0 )
color 128 128 128
end
# green
class
EXPRESSION ( [LEVEL] ge 2.0 and [LEVEL] lt 4.0 )
color 32 178 170
TEXT( [STATE] )
label
type truetype
position auto
font arial
minsize 10
maxsize 30
mindistance 100
buffer 100
force true
color 0 0 0
end
end
end
Thanks again for your time reading this message
Alexander Shostko
