[mapserver-users] labeling
Seamus Thomas Carroll
carrolls at unbc.ca
Wed Jul 10 19:19:01 EDT 2002
My method is very similiar except you have TILEINDEX and I have DATA and I
dont use CLASSITEM. My EXPRESSIONs work without CLASSITEM.
Is there a reason for using TILEINDEX over DATA and using CLASSITEM?
Seamus
On Wed, 10 Jul 2002, Joe Bussell wrote:
> We use a road classification value which is present in our *.dbf files.
> The trick is to define different classes depending on the data.
> LAYER
> NAME cityCenter
> GROUP defaultLayer
> TYPE POINT
> TILEINDEX td_sm.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "DISPCLASS"
> MAXSCALE 9000
> CLASS
> EXPRESSION ( ( [DISPCLASS] = 3 ) )
> #NAME "Big City"
> END
> CLASS
> EXPRESSION ( ( [DISPCLASS] = 6 ) )
> #NAME "Medium City"
> END
> END
> For roads it is very similar, except I have a functional road class to
> work with.
> Joe Bussell
> On Time Systems
> On Wed, Jul 10, 2002 at 12:41:26PM -0700, Seamus Thomas Carroll wrote:
> > Hi,
> > I am labeling various cities and roads I have the problem of roads and
> > smaller cities being labelled and the larger cities not being labeled.
> > All cities are part of the same layer and all roads are part of the same layer.
> > The map file is outlined as follows:
> > LAYER # road drawing layer
> > CLASS
> > # highway drawing layer
> > END
> > CLASS
> > END
> > END # end of road drawing layer
> > LAYER # road label layer
> > CLASS
> > # highways label info
> > END
> > CLASS
> > # road label info
> > END
> > END # end of road label layer
> > LAYER # city layer
> > CLASS
> > #Largest city info
> > #Labeling and drawing of points
> > END
> > CLASS
> > #Medium city info
> > END
> > CLASS
> > #Small city info
> > END
> > END # end of city layer
> > I want the labeling to go in this order of precedence:
> > 1) larger city
> > 2) small city
> > 3) highway
> > 4) road
> > Any suggestions?
> > At some zoom levels things look correct and at others they dont. I have
> > tried changing the order of the layers and the order of the classes
> > within the layers. The FORCE command wont be useful because there are
> > major cities side by side and I dont want overlap.
> > Thanks for reading this far and any suggestions would be much appreciated.
> > Seamus
