[mapserver-users] PHP, HOW??: Returning Results to Multiple Windows
Scott Carr
scarr at progbits.com
Tue Jul 16 15:26:49 EDT 2002
I don't believe it is possible to create two different transmissions within the
same call. (I could be wrong.)
What about displaying the map and including a link, called View Records, that
would pass the same query, but display the results instead of the map?
You could use <a href="..." target="new"> or something like it anyway.
Scott Carr
OpenOffice.org
Documentation Maintainer
http://documentation.openoffice.org/
Quoting "Hankley, Chip" <Chip.Hankley at GASAI.Com>:
> Kind of a generic server side processing question.
> I'm running a querybypoint operation w/ PHP MapScript. I can collect the
> results in an array, highlight the selected records, etc. etc., all in the
> same window. BUT, what I want to do is display the selected records in a
> table in a NEW window. So... I want the server-side stuff to do something
> like this.
> Receive Input
> V
> Query Shapefile
> V
> Return Results to Array
> V
> Refresh Map in Existing Window
> (showing selected records)
> V
> Display the Attributes of
> the Selected Records in a
> New Window
> It's this last step that I'm having a hard time with...I would think it
> should be simple. Thanks for any suggestions!
> Cheers!
> Chip Hankley
This mail sent through IMP: http://horde.org/imp/
