[mapserver-users] Still have autorotation problems
Michel, Isai ISAI.MICHEL at saic.com
Tue Jul 16 18:35:51 EDT 2002
Hello, it is me again (the person with the tiff automatic rotation
problems).
Please excuse the delay in response however I used to use hotmail but then
the IT department shutdown access because of a virus problem.  So now please
respond to my other email address: isai.michel at saic.com
Anyways, here is the current problem I have.
I have still not had any success with the autorotation.
Some people suggested that I MUST use the PROJ libraries.  So I downloaded
those, then compiled those, and then recompiled the mapserver.  I did:
$ make clean
$ ./configure --with-gdal --with-proj
$ make
The template file still shows the images in the middle of a box with
absolutely no rotation.  As previously requested:
I HAVE ATTACHED THE FOLLOWING FILES SO THAT SOMEONE MAY EDIT THEM AND HELP
ME:
start001.html
grid001.map
template001.html
LaserGrid-400_0000.tfw
LaserGrid-400_0001.tfw
I know that I do not have a projection definition but I do not know how to
write one.  Can someone please edit the files so that they may work properly
(I did not include the tiff images because it is rather big however the
pixel dimensions are 640x480) as was previously offered.  I really need to
get this to work so that I can automate the process.
Thank you very much and have a nice day.
Respectfully:
IML
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020716/14e64ddc/grid001.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020716/14e64ddc/LaserGrid-400_0000.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020716/14e64ddc/LaserGrid-400_0001.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020716/14e64ddc/start001.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020716/14e64ddc/template001.obj
