Fwd: RE: [mapserver-users] Still have autorotation problems
Lowell Filak
lfilak at medinaco.org
Wed Jul 17 11:55:53 EDT 2002
The following message was sent by "Michel, Isai" <ISAI.MICHEL at saic.com> on Wed, 17 Jul 2002 08:35:53 -0700.
> Yes, I read it right now. I recompiled mapserver with the options:
> --without-tiff --with-gdal --with-proj
> And now there is a big black box on the screen with no images on it. I am
> pretty sure the extents are right but for some reason nothing seems to be
> shown (in addition to no rotation issues).
> I previously included the .tfw files and the map file in a previous email.
> The files are less than 1 kb each so you could very easily check them and
> see if my .map file is fine. I think that would at least verify that my
> .map file is valid.
> If anyone could please see the files just to make sure, I think that would
> be very helpful.
> Thank you for your help.
> Respectfully,
> IML
> -----Original Message-----
> From: Lowell Filak
> To: Michel, Isai
> Sent: 7/17/2002 6:19 AM
> Subject: Re: [mapserver-users] Still have autorotation problems
> Did you see this:
> http://mapserver.gis.umn.edu/wilma/mapserver-users/0202/msg00335.html
> Lowell
> on Tue, 16 Jul 2002 15:35:51 -0700.
> > Hello, it is me again (the person with the tiff automatic rotation
> > problems).
> > Please excuse the delay in response however I used to use hotmail but
> then
> > the IT department shutdown access because of a virus problem. So now
> please
> > respond to my other email address: isai.michel at saic.com
> > Anyways, here is the current problem I have.
> > I have still not had any success with the autorotation.
> > Some people suggested that I MUST use the PROJ libraries. So I
> downloaded
> > those, then compiled those, and then recompiled the mapserver. I did:
> > $ make clean
> > $ ./configure --with-gdal --with-proj
> > $ make
> > The template file still shows the images in the middle of a box with
> > absolutely no rotation. As previously requested:
> > I HAVE ATTACHED THE FOLLOWING FILES SO THAT SOMEONE MAY EDIT THEM AND
> HELP
> > ME:
> > start001.html
> > grid001.map
> > template001.html
> > LaserGrid-400_0000.tfw
> > LaserGrid-400_0001.tfw
> > I know that I do not have a projection definition but I do not know
> how to
> > write one. Can someone please edit the files so that they may work
> properly
> > (I did not include the tiff images because it is rather big however
> the
> > pixel dimensions are 640x480) as was previously offered. I really
> need to
> > get this to work so that I can automate the process.
> > Thank you very much and have a nice day.
> > Respectfully:
> > IML
