[mapserver-users] Location Bar
Puneet Kishor
pkishor at GeoAnalytics.com
Mon Jul 22 08:46:36 EDT 2002
On Monday, July 22, 2002, at 06:41 AM, João Mário wrote:
> Hello!
> Thanks TCHaddad for aswer the questions which i have send before.
> The changes work fine!
> There is one more question to all...
> I'm using basic mapserver....
> There is anyway to hide the data from the Location bar?
> When i execute mapserver the location shows something like this:
> http://www.adress.com.br/cgi-
> bin/mapserver/mapserv?zoomdir=-1&zoomsize=10&mode=browse&layer2=layer4&layer3=
> layer1&layer4=layer3&layer5=layer7&submit=Consultar&imgxy=249.5+299.5&imgext=
> 1491.706003+834.766724+1668.094797+1046.433276&map=%2F%2Fhome%2Fhttpd%2Fhtml%2Flotes%2Fmaps.
> map&savequery=true&mapext=shapes
> There is anyway to execute mapserver and the location bar just show:
> http://www.adress.com.br/ ?
use post method instead of get... get sends the query string in the
url... post embeds it in a form... make sure you have the appropriate
hidden form variables defined that get populated on the client side with
javascript, etc. yes, it will be prettier. needless to say, it will be a
tad bit more complicated than what you are using till now.
pk/
