[mapserver-users] labeling question w/ OGR styleitem "auto"
Martin, Daniel
DMartin at erac.com
Tue Jul 23 17:32:52 EDT 2002
This is a known bug with Mapinfo OGR layers. It is listed in bugzilla,
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=168
What I've been doing as a workaround is creating two layers, one with
STYLEITEM "auto" and the other is a TYPE Annotation. If you give them both
the same name, they turn off and on together.
-Dan
-----Original Message-----
Sent: Tuesday, July 23, 2002 1:33 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] labeling question w/ OGR styleitem "auto"
Hi, I am using STYLEITEM "AUTO"
working fantastically well. However, I can't get labels to
render. The legend shows a white rectangle with a single pixel in
the middle of it.
However, if I remove the "auto" layer for labels and add a layer
with a manually defined class for the labels, then they render.
The OGR demo apps which are at dmsolutions.ca appear to just use
STYLEITEM "AUTO" and the labels magically render. What am I
doing wrong? I am using the stock symbols_mapinfo.sym which is
recommended for starting with. Here is the layer format, ogrinfo
output:
Layer name: INDDIST
Geometry: Polygon
Feature Count: 467
Extent: (68.123077, 8.030642) - (97.338745, 37.052483)
Layer SRS WKT:
GEOGCS["unnamed",
DATUM["MIF 0",
SPHEROID["WGS 84 (MAPINFO Datum 0)",6378137.01,298.257223563],
TOWGS84[0,0,0,0,0,0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
Dist_name: String (37.0)
Dist_HQ: String (40.0)
Dist_area: Real (13.2)
OGRFeature(INDDIST):1
Dist_name (String) = Adilabad
Dist_HQ (String) = Adilabad
Dist_area (Real) = 16105.00
Style = BRUSH(fc:#fff4d0,bc:#ffffff,id:"mapinfo-brush-2.ogr-
brush-0");PEN(w:1p
x,c:#000000,id:"mapinfo-pen-2.ogr-pen-0")
POLYGON ((...))
Here is the relevant parts of my mapfile:
SYMBOLSET "/Users/alex/Sites/mapserver/symbols/symbols_mapinfo.sym"
LAYER
NAME "INDDIST"
TYPE POLYGON
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION
"/Users/alex/Sites/mapserver/apps/tutorial/mapinfo/Map_Data/Asia/India/INDDI
ST.
TAB"
STYLEITEM "AUTO"
CLASS
NAME "Districts"
END
END # Layer
LAYER # districts labels
NAME "INDDIST"
TYPE ANNOTATION
CONNECTIONTYPE OGR
CONNECTION
ST.
TAB"
STATUS DEFAULT
STYLEITEM "AUTO"
LABELITEM "Dist_name"
CLASS
Name "Dist_name"
END # class
END # layer
So with the above mapfile layers, I see the regions nicely
rendered and colored, but not labeled. If I change the layer for
districts labels to the following, then the labels render.
NAME "INDDIST"
TYPE ANNOTATION
CONNECTIONTYPE OGR
CONNECTION
ST.
TAB"
STATUS DEFAULT
CLASS
NAME "District Name"
COLOR -1 -1 -1
LABEL
COLOR 0 0 0
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE BITMAP
SIZE MEDIUM
POSITION CC
PARTIALS FALSE
BUFFER 2
END # label
END # class
END # layer
TIA
Alex Rice, Software Developer
Architectural Research Consultants, Inc.
alex_rice at arc.to
alrice at swcp.com
