[mapserver-users] Re:HP11-64bit: Using Oracle spatial causes "bus error(coredump" in Apache
Bjarni Pjetursson Bjarni.Pjetursson at tietoenator.com
Wed Jul 24 03:42:53 EDT 2002
Hi Gregor,
haven't tried that but will do. At present I set the environment in a shell
before executing Mapserver. Works fine with shp-files.
You say you get no visible data from your Oracle layer. I've done this
without problems on Windows, so don't hesitate to ask. Have you chosen the
right projection for the layer?
Regards
Bjarni Thor Pjetursson
-----Original Message-----
To: mapserver-users at lists.gis.umn.edu
Sent: 23-07-02 11:19
Subject: [mapserver-users] Re:HP11-64bit: Using Oracle spatial causes "bus
Hi Bjarni,
have you allready tried to set environment variables in httpd.conf ?
(in httpd.conf)
<IfModule mod_env.c>
SetEnv ORACLE_SID g10
SetEnv ORACLE_BASE /u01/app/oracle
SetEnv ORACLE_HOME /u01/app/oracle/product/8.1.7
SetEnv ORA_NLS33 /u01/app/oracle/product/8.1.7/ocommon/nls/admin/data
SetEnv NLS_LANG "brazilian portuguese"
</IfModule>
I can connect to Oracle Spatial without problems , but the map is empty
(blank)  :-( and I don't know why ?
Datasource is a shapefile uploaded with shp2sdo tool and the file
version
works fine ....
If it works after this fix , can you see any map form SDO ??
thanks gregor
