[mapserver-users] projection help please
woodbri at swoodbridge.com
Wed Jul 24 14:26:57 EDT 2002
YES! Chip nails it!
Thank you, this was starting to drive me crazy!
Many thanks,
-Steve
On 24 Jul 2002 at 12:57, Hankley, Chip wrote:
> Steve -
> IF you're state plane data is in feet, then you may need to add a line to
> your projection def that will do the feet to meter conversion. I had a
> similar problem with some state plane data that was in feet. Here's the
> projection def for the layer that I was using.
> PROJECTION
> "proj=lcc"
> "lat_1=45.056389"
> "lat_2=44.745278"
> "lat_0=44.405556"
> "lon_0=-89.770000"
> "x_0=74676.149352"
> "y_0=0"
> "ellps=GRS80"
> "datum=NAD83"
> "to_meter=0.3048006096" <-- THIS LINE
> "no_defs"
> END
> This has always been confusing to me... and I just monkey around w/ it 'til
> it works. We end up w/ a lot of SP data in feet...parameters are in feet,
> etc.
> Anyway, this worked for me. HTH.
> Chip
> -----Original Message-----
> From: woodbri at swoodbridge.com [mailto:woodbri at swoodbridge.com]
> Sent: Wednesday, July 24, 2002 12:07 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] projection help please
> Arrrgh! This is my first attempt to work with layers in two different
> projections. I can get parcels to display, but not the roads layers
> below. The roads display just fine by themselves unprojected. The
> parcels show up just fine, they are in FL North state plane
> projection #903 and the roads are both latlong projection.
> Any help would be greatly appreciated.
> -Steve W.
> MAP
> NAME "gadsden"
> STATUS ON
> EXTENT 1850043.62398028 512249.445079203 2012425.97125672
> 626430.515528745
> SIZE 400 400
> IMAGECOLOR 255 255 255
> UNITS FEET
> IMAGETYPE GIF
> WEB
> IMAGEPATH "/home/httpd/html/web2/tmp/"
> IMAGEURL "/web2/tmp/"
> END
> PROJECTION
> "proj=lcc"
> "datum=NAD83"
> "lon_0=-84d30"
> "lat_1=30d45"
> "lat_2=29d35"
> "lat_0=29"
> "x_0=600000"
> "y_0=0"
> "no_defs"
> END
> LEGEND
> STATUS ON
> END
> SCALEBAR
> STATUS ON
> UNITS MILES
> SIZE 400 10
> STYLE 1
> COLOR 0 0 0
> TRANSPARENT ON
> END
> LAYER
> NAME "parcels"
> STATUS DEFAULT
> DATA "/data/maps/gadpar"
> TYPE POLYGON
> UNITS FEET
> LABELITEM "shortparce"
> LABELMAXSCALE 10000
> PROJECTION
> "proj=lcc"
> "datum=NAD83"
> "lon_0=-84d30"
> "lat_1=30d45"
> "lat_2=29d35"
> "lat_0=29"
> "x_0=600000"
> "y_0=0"
> "no_defs"
> END
> CLASS
> COLOR 153 255 204
> OUTLINECOLOR 0 0 0
> LABEL
> TYPE BITMAP
> SIZE TINY
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> END
> END
> END
> LAYER
> NAME "major roads"
> STATUS ON
> DATA "/data/maps/majroads"
> TYPE LINE
> UNITS DD
> PROJECTION
> "proj=latlong"
> END
> CLASS
> COLOR 255 0 0
> END
> END
> LAYER
> NAME "minroads"
> STATUS ON
> DATA "/data/maps/minroads"
> TYPE LINE
> UNITS DD
> PROJECTION
> "proj=latlong"
> END
> CLASS
> COLOR 0 255 0
> END
> END
> END
