[mapserver-users] Classifying layers from data in a DB
Vinko Vrsalovic
vinko at cprsig.cl
Thu Jul 25 00:08:32 EDT 2002
Hi!
I need some advice about what might be the right path to achieve
this:
I have some layers in shapefiles, and I need to classify them
from data that comes from an Oracle database (without Spatial
extension).
I've thought about these solutions:
1.- Grab the data, and add column(s) to the dbf file of the
shape, then set the expression and classitem of the layer
according to the new column(s)
2.- Grab the data, put it in a PostGIS DB and display as a
PostGIS layer
3.- ??? :-)
Which one would you do? Any suggestion is very welcome.
(BTW, I'm using MS 3.6.1)
Thanks,
Vinko Vrsalovic <vinko[|- at -|]cprsig.cl>
http://www.cprsig.cl
