[mapserver-users] help with dynamic layer
Dylan Keon keon at nacse.org
Thu Jul 25 13:58:28 EDT 2002
I'm trying to create a dynamic point layer using PHP Mapscript.  A
simple query to a Postgres database returns the UTM coordinates.  That
part works fine.  What isn't working is the rendering of the layer.  I
read through the various "dynamic layer" posts in the archives, but
still couldn't figure it out.  This is my first Mapscript attempt :-)
I'm sure it's a simple error (or errors) on my part.
The PHP code, map file, and error messages are below.  Any tips would be
great.  Thanks!
Dylan
###################### PHP and HTML code ######################
<?php
dl('php_mapscript.so');
// db connect parameters
$host = "localhost";
$user = "xxxxx";
$pass = "xxxxx";
$db = "xxxxx";
// open a connection to the db server
$connection = pg_connect("host=$host dbname=$db user=$user password=$pass");
if (!$connection) {
         die("Could not open connection to database server");
// generate and execute the query
$query = "SELECT utm_e, utm_n FROM sites";
$result = pg_exec($connection, $query) or die("Error in query: $query. "
. pg_last_error($connection));
// get the number of rows in the resultset
$rows = pg_numrows($result);
// MapObj and ImageObj settings
$map_path="/www/gis/mapfiles/";
$map = ms_newMapObj($map_path."test.map");
$img = $map->prepareImage();
// get dummy layer
$layer = $map->getLayerByName("sites2");
// loop through resultset, generating points
for ($i=0; $i<$rows; ++$i) {
    $row = pg_fetch_row($result, $i);
// echo "Record $i: UTM_E $row[0], UTM_N $row[1]<br>";
    $pt = ms_newPointObj();
    $pt->setXY($row[0],$row[1]);
    $pt->draw($map, $layer, $img, 0, "TEST");
    $layer->set('status', MS_ON);
    $layer->draw($img);
// create web image
$img=$map->draw();
$img_url=$img->saveWebImage(MS_PNG,1,1,0);
// close database connection
pg_close($connection);
<html>
<head>
<title>Test Map</title>
</head>
<body>
<table align="center">
<tr><td>
<input type="image" name="test_map" src="<?php echo $img_url?>">
</td></tr>
</table>
</body>
</html>
########################### map file ###########################
NAME TEST
SIZE 600 400
STATUS ON
SYMBOLSET "/www/gis/symbols/symbols.sym"
EXTENT 370000 4640000 1011000 5130000 #minx miny maxx maxy
UNITS METERS
SHAPEPATH "/usr/local/gis_data/state"
IMAGETYPE PNG
WEB
   IMAGEPATH "/www/tmp/"
   IMAGEURL "/tmp/"
END
LAYER
   NAME boundary
   DATA bnd
   TYPE polygon
   STATUS DEFAULT
   CLASS
     NAME "State boundary"
     OUTLINECOLOR 0 0 0
     COLOR -1 -1 -1
   END
END
LAYER
   NAME sites2
   TYPE POINT
   STATUS OFF
   CLASS
     COLOR 255 255 0
     OUTLINECOLOR 0 0 0
     SYMBOL 7
     SIZE 8
   END
END
END
####################### Error messages #########################
Warning: MapServer Error in msGetBitmapFont(): Invalid bitmap font. Must
be one of tiny, small, medium, large or giant. in
/usr/local/etc/httpd/htdocs/test.php on line 47
Fatal error: Call to a member function on a non-object in
/usr/local/etc/httpd/htdocs/test.php on line 48
