[mapserver-users] strange mapinfo layer
Alex Rice
alex_rice at arc.to
Thu Jul 25 20:03:35 EDT 2002
On Wednesday, July 24, 2002, at 05:23 PM, Daniel Morissette wrote:
> Hummm... this is bad... even though a layer with no geometries is
> useless to MapServer, it should not crash on it... this as a bug
> that we
> should fix since objects with "NONE" geometries are a valid case coming
> from MapInfo and other GIS formats.
> FYI I filed this in the MapServer bugzilla at
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=169
Daniel, here is some more info. There is only one file I've found
that causes this behavior. It's supposed to be a Mapinfo .TAB
file & it IS supposed to have point geometry in it. However,
ogrinfo insists on opening it with the ESRI Shapefile driver! The
shapefile output from ogrinfo is:
# ogrinfo Eslocs.TAB Eslocs | more
INFO: Open of `Eslocs.TAB'
using driver `ESRI Shapefile' successful.
Layer name: Eslocs
Geometry: None
Feature Count: 83
Layer SRS WKT:
(unknown)
ADDRESS: String (40.0)
PHONE: String (10.0)
MAPADD: String (40.0)
Let me know if you want a copy of these files Eslocs.*. Now I'm
going to try opening it in Mapinfo Pro and seeing if it thinks
it's a TAB file or something else.
Thanks,
Alex Rice, Software Developer
Architectural Research Consultants, Inc.
alex_rice at arc.to
alrice at swcp.com
