[mapserver-users] help with dynamic layer
woodbri at swoodbridge.com
Fri Jul 26 12:39:57 EDT 2002
Dylan,
Try something like this:
// MapObj and ImageObj settings
$map_path="/www/gis/mapfiles/";
$map = ms_newMapObj($map_path."test.map");
$img = $map->draw();
$layer = $map->getLayerByName("sites2");
$layer->set('status', MS_ON);
for ($i=0; $i<$rows; ++$i) {
$row = pg_fetch_row($result, $i);
// echo "Record $i: UTM_E $row[0], UTM_N $row[1]<br>";
$pt = ms_newPointObj();
$pt->setXY($row[0],$row[1]);
$pt->draw($map, $layer, $img, 0, "TEST");
$img_url=$img->saveWebImage(MS_PNG,1,1,0);
When you are using this style of adding objects to the map
dynamically you have to draw the map first THEN add you dynamic data
on top of the already rendered map.
This method has the problem that if you have a high density of
objects to add to the map it can obscure the underlining map. You
also might want to set LABELCACHE FALSE for the layer.
-Steve
On 26 Jul 2002 at 11:29, Lowell.Filak wrote:
> I think there may be a couple of things missing.
> I don't see where the "data" value is set for the layer & I don't see
> where the addPoint is being done to add the point(s) to the data shapefile
> before rendering the layer.
> Lowell F.
> On Thu, 25 Jul 2002, Dylan Keon wrote:
> > Hi,
> > I'm trying to create a dynamic point layer using PHP Mapscript. A
> > simple query to a Postgres database returns the UTM coordinates. That
> > part works fine. What isn't working is the rendering of the layer. I
> > read through the various "dynamic layer" posts in the archives, but
> > still couldn't figure it out. This is my first Mapscript attempt :-)
> > I'm sure it's a simple error (or errors) on my part.
> > The PHP code, map file, and error messages are below. Any tips would be
> > great. Thanks!
> > Dylan
> > ###################### PHP and HTML code ######################
> > <?php
> > dl('php_mapscript.so');
> > // db connect parameters
> > $host = "localhost";
> > $user = "xxxxx";
> > $pass = "xxxxx";
> > $db = "xxxxx";
> > // open a connection to the db server
> > $connection = pg_connect("host=$host dbname=$db user=$user password=$pass");
> > if (!$connection) {
> > die("Could not open connection to database server");
> > // generate and execute the query
> > $query = "SELECT utm_e, utm_n FROM sites";
> > $result = pg_exec($connection, $query) or die("Error in query: $query. "
> > . pg_last_error($connection));
> > // get the number of rows in the resultset
> > $rows = pg_numrows($result);
> > $img = $map->prepareImage();
> > // get dummy layer
> > // loop through resultset, generating points
> > $layer->draw($img);
> > // create web image
> > $img=$map->draw();
> > // close database connection
> > pg_close($connection);
> > <html>
> > <head>
> > <title>Test Map</title>
> > </head>
> > <body>
> > <table align="center">
> > <tr><td>
> > <input type="image" name="test_map" src="<?php echo $img_url?>">
> > </td></tr>
> > </table>
> > </body>
> > </html>
> > ########################### map file ###########################
> > NAME TEST
> > SIZE 600 400
> > STATUS ON
> > SYMBOLSET "/www/gis/symbols/symbols.sym"
> > EXTENT 370000 4640000 1011000 5130000 #minx miny maxx maxy
> > UNITS METERS
> > SHAPEPATH "/usr/local/gis_data/state"
> > IMAGETYPE PNG
> > WEB
> > IMAGEPATH "/www/tmp/"
> > IMAGEURL "/tmp/"
> > END
> > LAYER
> > NAME boundary
> > DATA bnd
> > TYPE polygon
> > STATUS DEFAULT
> > CLASS
> > NAME "State boundary"
> > OUTLINECOLOR 0 0 0
> > COLOR -1 -1 -1
> > END
> > END
> > LAYER
> > NAME sites2
> > TYPE POINT
> > STATUS OFF
> > CLASS
> > COLOR 255 255 0
> > OUTLINECOLOR 0 0 0
> > SYMBOL 7
> > SIZE 8
> > END
> > END
> > END
> > ####################### Error messages #########################
> > Warning: MapServer Error in msGetBitmapFont(): Invalid bitmap font. Must
> > be one of tiny, small, medium, large or giant. in
> > /usr/local/etc/httpd/htdocs/test.php on line 47
> > Fatal error: Call to a member function on a non-object in
> > /usr/local/etc/httpd/htdocs/test.php on line 48
