[mapserver-users] PostGIS and Temporary Tables
Dave Blasby
dblasby at refractions.net
Fri Jul 26 17:26:36 EDT 2002
This is probably a problem because there is no true OID in the temporary
table you're using.
Use the latest CVS version of mapserver, and :
DATA "geometry from (select * from temporary_table) as foo using unique
<unique> using SRID=<srid>"
Where <unique> is the name of a column in temporary_table that uniquely
identifies a row, and <srid> is the SRID of your data.
Using the CVS version will also give you more error information if this
doesnt work.
dave
ps.
If you do a "select * from temporary_table limit 5" you'll see
geometries described like 'SRID=#;<geometry data>'. This '#' is the
SRID of your data.
