[mapserver-users] No Image Output
Lowell Filak
lfilak at medinaco.org
Mon Jul 29 08:41:04 EDT 2002
Check out the first section of:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptDebugging
it explains the logging process.
Lowell F.
The following message was sent by Alexander Pucher <pucher at atlas.gis.univie.ac.at> on Sun, 28 Jul 2002 13:50:51 +0200.
> Hi,
> I've just finished my Mapserver-Setup using the following components:
> SuSE Linux v.8.0 (Kernel 2.4.18-4GB)
> PostgreSQL v.7.2.1
> PostGIS v.0.7
> freetype 1.3
> gd-1.8.4 (patched version with GIF support)
> proj-4.4.5
> gdal-1.1.7
> w3c-libwww-5.4.0
> libgeotiff-1.1.4
> PHP v.4.2.1
> UMN Mapserver v.3.6
> gmap-ms36
> $ mapserv -v gives me the following output:
> MapServer version 3.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> Itasca demo works without problems!!!
> but GMAP demo doesn't produce any GIF's in my /tmp/ms_tmp directory!!!
> The source code of the HTML output file looks perfect until the PHP
> statement <?php GMApDrawMap() ?>
> I checked the mailinglist entries concerning this problem, and also
> checked the permissions of the /tmp/ms_tmp dirs. BTW, the Itasca-demop
> writes its file into there, so the permissions should be OK.
> Any suggestions on this?
> How can I (quick) test if the php_mapscript.so I compiled is working
> properly ?
> I tried to enable logging by _not_ commenting the resp. line in the
> mapfile, but nothing gets logged ? How do I log Mapserver actions??
> Thanks you
> alex
