[mapserver-users] Display GeoTIFF raster data
Pericles S. Nacionales
pnaciona at gis.umn.edu
Mon Jul 29 15:30:42 EDT 2002
Are you using an RGB image? If you are, you'll need to convert it into
a bitmap (indexed color) image. MapServer doesn't yet support RGB
images. Hopefully, your software can export GeoTIFFs. If not, you'll
have to create a world file (with extension .wld). See Tom Kralidis'
info about world files: http://www.kralidis.ca/gis/worldfile.htm
Remember to use the extension ".wld" and not ".tfw".
Most image manipulation software (i.e. Gimp or Photoshop) can convert
RGB GeoTIFFs to bitmap but can't keep the GeoTIFF header. If you use
one of these software, you'll need to create a world file to add
georeferencing to your image. If you have an image processing software
(i.e.: Imagine, Geomatica) you can export your bitmap image in GeoTIFF
format and you won't need a world file.
Of course you should also check your projections and extents... If
you're trying to overlay your image with the tutorial data, it won't
happen. If you're trying to overlay a Transverse Mercator (or UTM)
projected image with unprojected (with lat/lon coordinates) vector data,
it won't happen... unless you already know how to reproject your data
on the fly (that's section 4 on the tutorial).
I hope this helps.
-Perry
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of Stefan
Stern
Sent: Monday, July 29, 2002 7:40 AM
To: MAPSERVER
Subject: [mapserver-users] Display GeoTIFF raster data
Hi NG,
after spending some days on trying to display a GeoTiff image in
mapserver I ask for your advice.
Compared to the example used in the tutorial (
http://terrasip.gis.umn.edu/projects/tutorial35/s2/s2ex3.html ) image
dataset is more complex.
It includes the following values for each pixel:
Scrn: R:146 G:103 B:50
Projection: GEOTIFF (Transverse Mercator)
Map: 267457.50E,197788.50N Meters
LL : 3.548576N, 1.228218W
Data: R:136 G:102 B:68
How do I display this image in mapserver?
Do I need to rewrite header information of the source image or is it
just a question of "How to display it in mapserver"?
Is there some additional documentation / reference available?
Thanks for suggestions.
Regards,
Stefan
