[mapserver-users] Back from query
David Turover
dturover at student.santarosa.edu
Mon Jul 29 17:58:07 EDT 2002
> I 'm using mapsever and I'm having the following problem.
> I had created a submit button to back to the where the original map is
> after mapsever execute a query.
> This is the code:
> <input type="submit" name="Submit" value="Back">
> </th>
> </tr>
> </table>
> <input type="hidden" name="map" value="[map]">
> <input type="hidden" name="savequery" value="true">
> <input type="hidden" name="zoomsize" value=2>
> </form>
> But when it happens all the layers are reset.
> And i want to back and keep all selected layers.
> Can i do it?
> Thanks
> João.
You will want to have hidden <input> tags to repeat all of the environment
variables used by the query page, with these three exceptions:
Set mode to "browse" or simply don't set it (browse is the default)
Make img.x half the width of your image
Make img.y half the width of your image
