[mapserver-users] PHP MapObj serialization?
Daniel Morissette
morissette at dmsolutions.ca
Tue Jul 30 09:41:26 EDT 2002
Vinko,
The main reason why you cannot serialize a MapObj in PHP is that it is
just a set of wrappers on top of MapServer's internal C structures, and
hte PHP serialization functions cannot do anything about them... so you
get "invalid handle" errors from the serialized object because the
internal C structures don't exist any more.
In the current version, the only way to save the state of a mapObj is to
use $map->save($temp_filename), store the $temp_filename in your
$_SESSION, and load the saved mapfile on further requests.
I don't think serializing mapObj will ever be possible given the nature
of MapScript, but maybe some tricks can be implemented eventually to
save the mapfile to a session variable, or even have support for
persistent mapObj... but that's very far in our priority list.
Daniel
Vinko Vrsalovic wrote:
> Hello,
> I'm trying to serialize a PHP MapObj for further use (another
> page from the same session).
> From what I've read, this will not work if you don't have the
> definition of the class in all the pages the object will be
> used.
> I also presume that dl'ing the .so is not what is meant by
> definition of the class. Is serializing and/or saving in a
> session variable the mapobj possible?
> Ex:
> p1.php
> <?php
> dl('php_mapscript.so');
> session_start();
> $map = ms_newMapObj("file.map");
> $map->draw();
> $_SESSION['map'] = $map;
> /* or
> $_SESSION['map'] = serialize($map);
> p2.php
> <?php
> session_start();
> $map = $_SESSION['map'];
> /* or
> $map = unserialize($_SESSION['map']);
> As I understood from the docs the serialization is not needed when
> using $_SESSION.
> If i serialize/unserialize, i get the long forgotten:
> Fatal error: Object has an invalid _handle_ property in ...
> If i don't serialize/unserialize, i get the same error. :)
> Is there a trick to make PHP see the MapObj definition?
> Thanks,
> Vinko Vrsalovic <vinko[|- at -|]cprsig.cl>
> http://www.cprsig.cl
