[mapserver-users] WMS client with JPEG
Daniel Morissette morissette at dmsolutions.ca
Tue Jul 30 09:47:33 EDT 2002
Well, the only reason why JPEG is rarely used is because it doesn't
support transparency and hence doesn't allow you to combine multiple WMS
layers in a single maps.
Except for that transparency issue there should be no reason why JPEG
couldn't work. If you have a way to reproduce this crash systematically
then please create a bug in bugzilla about this with your mapserver, os,
etc, version information, your mapfile (or at least the layer defn that
crashes), and steps to reproduce the problem.
Daniel
"Lowell.Filak" wrote:
> Judging by previous posts to the group, it appears that the request must
> be image/gif or image/png.
> Lowell F.
> On Tue, 30 Jul 2002, Stepan Kafka wrote:
> > Hi all,
> >   I am using Mapserver as WMS client. It works well when remote WMS server
> > provides GIF format. But when format=image/jpeg, my Mapserver crashes or
> > returns "Image format is not supported". In the older versions of MS it
> > revealed also with PNG format but in 3.6.2 pngs are OK. Does anybody have an
> > idea?
> > Thanks
> > Stepan Kafka
