[mapserver-users] PHP MapObj serialization?
woodbri at swoodbridge.com
Tue Jul 30 09:49:57 EDT 2002
Vinko,
You can not serialize the map object as it is not a php object be a
containor for a C structure. What you would have to do is save the
currect map object as a mapfile in a temp directory using a unique
file name and save the file name in the session variables, then
restore the map object from the map file you saved.
-Steve W.
On 30 Jul 2002 at 1:44, Vinko Vrsalovic wrote:
> Hello,
> I'm trying to serialize a PHP MapObj for further use (another
> page from the same session).
> From what I've read, this will not work if you don't have the
> definition of the class in all the pages the object will be
> used.
> I also presume that dl'ing the .so is not what is meant by
> definition of the class. Is serializing and/or saving in a
> session variable the mapobj possible?
> Ex:
> p1.php
> <?php
> dl('php_mapscript.so');
> session_start();
> $map = ms_newMapObj("file.map");
> $map->draw();
> $_SESSION['map'] = $map;
> /* or
> $_SESSION['map'] = serialize($map);
> p2.php
> <?php
> session_start();
> $map = $_SESSION['map'];
> /* or
> $map = unserialize($_SESSION['map']);
> As I understood from the docs the serialization is not needed when
> using $_SESSION.
> If i serialize/unserialize, i get the long forgotten:
> Fatal error: Object has an invalid _handle_ property in ...
> If i don't serialize/unserialize, i get the same error. :)
> Is there a trick to make PHP see the MapObj definition?
> Thanks,
> Vinko Vrsalovic <vinko[|- at -|]cprsig.cl>
> http://www.cprsig.cl
